Counter/Timer
PWM output on cDAQ-9178 Chassis PFI Line
The front panel of cDAQ-9178 Chassis comes with two built in BNC connectors identified as PFI0 and PFI1. My question is: can I use both of these to simultaneously access two of the onboard counters (housed in the Chassis), to generate PWM output for two BLDC motors? I know I can access the onboard counters using a Digital I/O module, but that's not what I am looking for. The Chassis PFI lines can be used for Counter Input, as shown here: https://forums.ni.com/t5/Example-Code/CDAQ-9178-Count-Digital-Events-Without-Digital-Module/ta-p/352.... But can they be used for Counter Output as well? And will I be able to change the duty cycle of the bldc motor while the program is running?
(3,742 Views)
Accepted by topic author laz_2331
How to Output a Digital Signal from a cDAQ PFI Chassis Terminal
https://tmesystems.net/
(3,715 Views)
Is it possible to slow this down to a 125 Hz output?
(3,095 Views)
If you read and run the example from the same link of How to Output a Digital Signal from a cDAQ PFI Chassis Terminal, you can change the output frequency.
(3,090 Views)
