Counter/Timer
PCI-6602 up-down counter direction
We use a PCI-6602 counter/timer card in an automated test fixture.
The software is written for Labwindows/CVI using NI-DAQmx.
Counter 0 is configured as an up/down counter as follows:
SOURCE_0 (PFI_39) on Pin 2 = count input
UP_DOWN_0 (PFI_37) on Pin 40 = direction input
Question:
Is there any way, under software control, to reverse the sense of the direction input?
Kirk Mitchell
Project Engineer
(4,831 Views)
The only way I can think of doing it would be to have one of the DIO lines on the PCI-6602 control some external circuitry to change the sense direction.  The 6602 does not allow for this internally.
Ben
Certified LabVIEW Associate Developer
Certified TestStand Developer
(4,815 Views)
OK, Thats what I suspected.
We're already using the hardware solution on another channel.
This is an addition that would be easier if it could be done in software.
Oh well.
Thanks much for your input,
Kirk
(4,785 Views)
What are the signals ? I think there is a software solution if they were quadrature signals (eg A and B channels of a quadrature encoder).
(4,777 Views)
  The signals originate on a resolver to digital converter and get processed by some logic into count and direction.
We have to use the count and direction signals.
I'm curious, how do you "reverse" the quadrature count direction?
Kirk
(4,769 Views)
Instead of using the default terminals for the counter inputs, you can use DAQmx properties to specify the terminals to which the A and B signals of the quadrature encoder are connected. By inverting these connections (case in your code), you will get an inverted count direction.
For A input : funtions palette >> Measurement I/O >> DAQmx - Data Acquisition >> DAQmx Channel Property Node >> place on diagram >> Property >> Counter Input >> Position >> A Input >> Terminal
(4,747 Views)
