I haven't found any information about an issue like that. So here are some comments, questions and suggestions:
- I don't think that it's very probable that the problem is related to an hardware issue but if you have a chance to try another board of the same type it would be interesting to know if the problem occurrs with this one, too.
- Upgrading NI-DAQ could potentially solve the problem. There are two options:
1. Upgrade to
NI-DAQ 6.9.3 which is the last version of traditional NI-DAQ. This is a minor upgrade from the application development point of view but it also contains some fixes for the 660x devices.
2. Upgrade to
NI-DAQ 7.4 which contains the old traditional NI-DAQ API based on NI-DAQ 6.9.3 and the new DAQmx API. Using DAQmx means rewriting the code but on the other hand the new driver and API mean a lot of improvements.
- Whenever your system is in the state you describe is it possible to use the board in MAX? Do you see the same behavior there? Do you receive any errors?
Jochen Klier
National Instruments Germany
