I am trying to use a PCI-6280 board with NI-DAQmx and C++ to measure the frequency of an approximately 36kHz external digital clock source.
I have been playing with the "Dig Freq-Low Freq 1 Ctr" example in the NI-DAQmx ANSI C examples directory, trying to get it to work. All I have gotten so far is error -200474 -- "Specified operation did not complete, because the specified timeout expired" -- in response to the call to the DAQmxReadCounterScalarF64() function.
I think I am connecting the external clock source to the wrong input terminal.
I am connecting the external clock source to pin 37, which the documentation says is the Ctr0 source terminal. I have also tried the other Ctr0 terminals (gate, aux, and out) and no luck.
What am I doing wrong? Where should I connect the input signal so I can successfully measure the digital frequency?
Any help will be appreciated! Thanks,
Markus Svilans.
