hi
i am using an PC-TIO-10 card. i used LabVIEW 6.1 without any problems. Now i upgraded to LabVIEW 7.1. The card is not supported by the DAQ 7.x. drivers anymore. So i want to use the DAQ 6.9.3 driver. i have problems installing this DAQ driver under LabVIEW 7.1 so that it is recognized and i can use the daq VIs in the functions palette.
i tried installing LabVIEW without the DAQ 7.x. drivers and then installed the daq 6.9.3 driver. The problem is that there are no DAQ VIs in the functions palette, so i cannot use the device. However, it does work in the measurement explorer.
i need some advice how to install the driver correctly
thanks for your help
holger
