Counter/Timer
Need event counter for LabPC+ with 8253 under windows 3.1
I work at a University and we are hard pressed for cash/equipment. I have Labview 3.0.1 and a LabPC+ card (with the 8253 counter) on an old 486 machine. Since the experiment I want to use this in is run only once per year, I want to use this setup to avoid tying up a newer, more expensive computer running Labview 6i. However, all the vi's I have found so far are too new. Does anyone have an old vi that would work for event counting (ttl pulses from an optical encoder) on this old system? Should I, or do I have to get hold of NI DAQ 5.05, and if I do, where do I find this?
Gary
(5,168 Views)
I would recommend downloading NI-DAQ 5.0.5 from the Drivers and Downloads section at support.ni.com. If you look under the "All" view, you will find a link to NI-DAQ 5.0.5.
Erin
(5,168 Views)
