Counter/Timer
NI-9361 Counter doing multiple counting jobs including incremental encoders, edge counting, and frequency
Can one physical NI-9361 counter module with 8 channels perform multiple counting jobs simultaneously? I am trying to use it to perform those 5 following tasks:
1. Edge counting 1, Single-ended, Channel 1
2. Edge counting 2, Single-ended, Channel 6
3. Frequency 1, Single-ended, Channel 2
4. Frequency 2, Single-ended, Channel 3
5. Incremental Angular Encoder (A, B, and I), Differential, Channels 0, 4, and 7
I tried it but everytime I run the code, I either get the 1-4 tasks running or the task 5 running, but never all of them together. Is it a limitation in the hardware module?
(1,321 Views)
What is the behavior when it is not working? Are you getting an error? Or do you only get outputs from specific channels?
https://tmesystems.net/
(1,289 Views)
When I run the program for the first time, I get the incremental encoder data but no edge counting/frequency. When I stop and re-run the program the second time, I get the edge counting/frequency data but no incremental encoders. Third time goes back to first time outcome, and so on ...
(1,268 Views)
