When I use ND_SWITCH_CYCLE will the timer wait until it has completly finished count1 and count2 before loading the new values, or, for example, if it is on count1 and I call switch cycle will it load count2 immediately.
Also, 2VIEAM6I makes it look like switch_cycle can only be used once, because it says the new values are loaded in C and D. Can this be repeated multiple times?
Thanks.
