I'm using LabView 7.0 and when running the VI, I get this error message below:
Error -200137 occurred at DAQmx Start Task.vi
Possible reason(s):
Initial delay, high time, and low time property values are inconsistent with one or more counter timebase properties.
The conflicting properties must satisfy the following restraint:
2 / Counter Timebase Rate <= X <= Counter Maximum Count/ Counter Timebase Rate, where X = Initial Delay, High Time, and Low Time and where Counter Timebase Rate = Master Timebase Rate / Counter Timebase Master Timebase Divisor or is inferred from the Counter Timebase Source selection.
Property: CO.Pulse.HighTime
Corresponding Value: Inf
Property: CO.Pulse.LowTime
Property: CO.Pulse.Time.InitialDelay
Corresponding Value: 0.0
Property: CO.CtrTimebaseSrc
Corresponding Value: MasterTimebase
Property: CO.CtrTimebaseRate
Corresponding Value: 20000000.0
Property: CO.CtrTimebaseMasterTimebaseDiv
Corresponding Value: 1
Property: MasterTimebase.Rate
Possible Internal Timebase Rates: 20000000.0, 100000.0
Counter Maximum: 16777215
Channel Name: Dev1/ctr1
Task Name: _unnamedTask<3>
