I am trying to build an installer for my application, and I can use the installer successfully on any system where LabVIEW is already installed. However, when I use it on a fresh system, I get a message that says "You must install LabVIEW 8.2 or later on the system before you can run this setup."
I am including the LabVIEW run time engine in the installer. Is there anything else that I am leaving out when I build the installer? Is the installer supposed to work on a fresh system that does not already have the run time engine installed?
S G
Certified LabVIEW Architect, Certified TestStand Architect, Certified Professional Instructor
