Counter/Timer
I installed the NI-6601 Timer/Counter software and hardware. Run examples written in VB provided with NI-DAQ. Got error:
"CWCounter.Configure"
Does anyone know why and how to get the problem resolved?
Thank you for help." I looked into System - Device Manager then
Data Acquisition Device - in the PCI-6601 Properties window - NI DAQ information tab:
PCI Device information:
Bus number 0
Device number 10
Serial number 0xC12245
Do I need to do Device Configuration? & How?
Thank you
(4,762 Views)
In order for the examples to work correctly, you need to make sure you have configured the CTR control for your setup. By right-clicking on the CTR control, you can bring up the properties window. Look through the tabs there to make sure that the settings are relevant.
Most importantly, make sure that the Device selected on the general tab is the NI-6601. By default, the Device is just the first device in your computer. This could or could not be the correct hardware, and a mistake here would definately generate a configuration error.
(4,762 Views)
