I trying since a mounth to find how to make interrupts with the lab-pc 1200 card , but i did not found how.I need answer,step by step, because i'm beginer.Thanks
You need to use the NI-DAQ function named Config_DAQ_Event_Message to generate a call back when a particular event happens. There are 10 different legal events that can generate a call back function to handle the interrupt. To get more familiar with that function, go to NI-DAQ help and search for the function at the index tab. On the help you will find a description about all the event that can generate interrupts. Hope this helps. Filipe Altoe Application Engineer National Instruments
