Dear All
I am using the Measure Period VI in Labview 6 to get the period of an external signal. The VI works fine but the internal timebase used by default in the VI (20MHz) is too high a frequency (i am looking at periods of between 1 and 4 seconds).
I am using an E series board and from the help files i understand there is another internal timebase (100KHz) which alolows measurement of periods of up to 167 secs rather than 838ms with the 20Mhz timebase.
How do i select this timebase for the VI, there is even a note on the VI which says 'This calculation assumes max timebase is selected as the source'.
Please Help, i'm almost finished my VI apart from this!!
Regards Ro
ss
