Using LabVIEW, and I'm afraid that I am just a beginner. I am currently using the PCI-MIO-16E-4 board, but will actually be using a PCI-6203E eventually.
Anyway, what I want to do is start counting edges on a TTL pulse coming from a gear tooth sensor. The counting is started by a seperate, single TTL pulse coming from an opto-switch. That is all fine. I then want to send a pulse to my injector after an exact no. of pulses. The incoming rate will be no more than 5400Hz, and outgoing 25Hz. I want a similar setup for ignition, but that is secondary for the moment, unless the solution I can come up with requires more counters of course!
I have experimented with Generate Delayed Pulse, but th
ere just seems so much to take in at once.
Any help would be appreciated.
