Counter/Timer
Frequency and Duty Cycle measurement with NI 9361
in the LabVIEW examples there is a Counter - Read Pulse Duty Cycle and Frequency (Continuous).vi
As in this VI, I want to use the Counter 1D Pulse Freq 1Chan NSamp type reading, so that I get a Cluster with frequency and duty cycle.
I have a NI 9361 module. If I select the physical channel "NI_9361/ctr0" on the front Panel, I get an error -200431:
"Selected physical channel does not support the measurement type required by the virtual channel you are creating."
Can anybody tell me how to measure frequency and duty cycle of a PWM Signal using NI 9361?
(7,481 Views)
just for the accuracy:
Chassis: NI cDAQ-9184
LabVIEW 2015 SP1 f5
DAQmx 17.1
(7,460 Views)
Hello Madottati
you have to use two counters and wire a bridge between the two inputs. This module do not support combine measurements like semi period and period with frequency measurement. In the datasheet you find the possible options
best regards
Alexander
(7,458 Views)
thanks for your reply. It's no Problem to use two Counter Inputs, the Problem is to configure the two Tasks.
If I run the attached VI, I get an error -200287 : Some or all of the samples requested have not yet been acquired.
Can you help me how to configure it?
(7,446 Views)
Hello Madottati
sorry i do not have the hardware at the moment so i can not test
bassed on this kb:
How Many Different Tasks Can Concurrently Run on a CompactDAQ Chassis Gen II?
The NI 9361 only supports a single task. If you need to use multiple counters from the NI 9361, you need to add all the required counters to the same Task.
best regards
Alexander
(7,441 Views)
You could also use the same physical channel by remapping the terminal using the DAQmx Channel property node.
by default /ctr0 maps to /PFI0   ....   ctr7 maps to /PFI7
(1,169 Views)
