11-30-2018 05:38 PM
Hi! I'm currently building a photon counter using the USB-7856R R series multi function rio. I have attached the labview program I'm using to count 1VPP square waves, and it works just fine. However, I eventually want to use it for photon counting, and our photon counter only outputs a signal of 200mV, which from what I understand is too low for any of the FPGA logic structures. Am I correct in this, and if so, is there any way to circumvent the issue?
Thank you!
12-03-2018 01:39 PM
Hi JCard,
You are correct on the digital logic levels. 200mV is too low for digital output.
As I see it, there are two main routes forward (there may well be others).
1. Find a way to increase the voltage (e.g. amplifier)
2. Switch to analog input and count when the voltage exceeds a particular threshold. (Potentially helpful example)
Best of luck with the photon counting!
