08-24-2020 12:00 AM
Is anyone aware of any NI hardware which supports DSI3 bus interface? I want to simulate some signals in DSI3 bus.
Ref: https://www.dsiconsortium.org/downloads/DSI3_%20Bus_Standard_r1.00.pdf
Ajay.
09-19-2023 04:27 AM
12Ch DSI3 Slave Simulator Module(CPCIe)
conforms to CPCIe 1.0
12-channel DSI3 Slave node simulation
Support CRM, PDCM mode
Simulation of data link layer and application layer using FPGA。
Application Layer Part (AK2)
This part mainly simulates the following commands for E524.17:
1 Start standard measurements
2 Start advanced measurements
3 Stop Measuring
4 Measurement data access
5 Status Reading
Other commands can also be developed according to the actual needs of customers, such as impedance testing, EEPROM access, read PDCM status commands, etc.
10-07-2023 09:52 PM
Where can I buy it?
05:31 AM
- last edited on
10-27-2023
09:58 AM
by
NI_Community_Su
Hi, JasonBro
Of course you can buy it. Please reach out for detail info,thanks.
05-12-2026 09:44 AM
You can find more about YEAE DSI3 USS a professional-grade solution designed to emulate complex ultrasonic sensor interactions within advanced HIL environments YEA Engineering DSI3 Ultrasonic Sensor Simulator .
Susanna Tadevosyan
