I have 4 Quadrature Encoder that output RS422 signals that I would like to connect to the NI-6602 board. Will the differential signal levels of the RS422 match with NI-6602 counter timers inputs? Does any one have an example of the pin numbers to connect the A,!A,B,!B,Z and !Z signals to for the NI-6602 card.
Here is the PDF to the NI-6602 Counter Timer board:
http://www.ni.com/pdf/products/us/4daqsc386-393_386-387.pdf
Thanks for your help.
