02-06-2026 09:57 AM
Urgent
I purchased three NI 9361 cards last year.
For one of the cards. I have everything unwired except a ground wired to COM to ground.
I have set all 8 channels to single ended with 5V pullup.
Here is what I get when I probe.
DI5+ / pin 14: Nothing
DI5- / pin 32: + 5V
DI4+ / pin 16: +5V
DI- / pin 35: Nothing
How am I getting this inconsistency? Could it be the Dsub or the NI Card? all measurements where with the oscilloscope referenced to the COM ground. Am I missing something in the documentation?
Let me know if you want any screenshots or documentation. Happy to provide anything.
02-06-2026 10:03 AM
Please share a wiring diagram of the connection. In addition, I recommend using a DMM to measure the voltages.
For SE mode, you should not care about the signal on DI- and must leave it not connected.
02-06-2026 10:47 AM - edited 02-06-2026 10:47 AM
"For SE mode, you should not care about the signal on DI- and must leave it not connected."
That's exactly the problem, I am not seeing 5V on one of the DI+ channels, and yet 5V on the DI-. Everything is unwired, just probing in directly.
See attached photos for wiring.
02-06-2026 11:36 AM
Update santo_13. Luckily, because I have 3 NI-9361. I powered off the cabinet and swapped them out. using a digital multi meter to probe each + and - DI on the positive side of my multi meter, with the negative side of my multimeter probed to pin 36 (COM). Here are the results. I then power it off again and swapped the cards again, and got the same differing results on card 1. No change to the FPGA or any of the programming. All wired as singled ended with 5V pullup.
| Card 1 | Card 2 | Card 1 Check 2 | ||||||||||
| Channel | Pos | Neg | Channel | Pos | Neg | Channel | Pos | Neg | ||||
| DI0 | 4.76 | 3.71 | DI0 | 4.77 | 3.71 | DI0 | ||||||
| DI1 | 4.76 | 3.71 | DI1 | 4.76 | 3.72 | DI1 | ||||||
| DI2 | 4.76 | 3.71 | DI2 | 4.77 | 3.72 | DI2 | ||||||
| DI3 | 4.76 | 3.71 | DI3 | 4.76 | 3.72 | DI3 | ||||||
| DI4 | 4.76 | 3.71 | DI4 | 4.76 | 3.72 | DI4 | ||||||
| DI5 | 0.09 | 4.2 | DI5 | 4.76 | 3.72 | DI5 | 0.09 | 4.2 | ||||
| DI6 | 4.76 | 3.71 | DI6 | 4.76 | 3.72 | DI6 | ||||||
| DI7 | 0 | 0 | DI7 | 4.76 | 3.71 | DI7 | 0 | 0 | ||||
02-08-2026 11:47 PM
Based on your observation, I do think there is something wrong. Please raise a technical support request for NI to look into the issue.
