Hi peabody124,
Here is what I understand is happening:
1. You insert a NI 6608 into slot 2 of your PXI-1045
2. You run a triggered counter edge input task on the NI 6608 and a NI 6289 counter
The results of the counter task are divided into each other to achieve a ratio: 6608 buffered counter result / 6289 buffered counter result. The ratio achieved is 0.9999963
That makes sense to me as you are triggering the NI 6608 and NI 6289 simultaneously then counting edges from the PXI backplane. They should correlate very closely.
Is that correct so far?
For the second test, a DAQmx Export Signal vi was used to route the 10Mhz Ref Clock from the backplane onto a PXI_Trig line, a 6608 counter and 6289 counter task created to count edges on that PXI_Trig line. The ratio this time was 1, implying they both saw the same number of edges.
How does that imply the 6608 is not driving the backplane?
In normal usage, the NI 6608 is placed in slot 2 of the PXI chassis, the chassis detects the clock driving the backplane and turns off it's clock. The chassis 10 Mhz now comes from the NI 6608. Normally you would use a frequency counter of better precision than 0.075 ppm to check the accuracy of the backplane clock.
Finally, measuring PXI_Trig6 will report 0 unless you route something to it. This can be done with a DAQmx Connect Terminals. I'm attaching code that shows how to do this.
Please let me know the results of running this LabVIEW 8.2 VI.
Have a great evening.
MatthewW
Message Edited by Matthew W on
12-05-2007 06:04 PM
