le 05-04-2006 03:09 AM
le 05-04-2006 06:34 AM
le 05-05-2006 03:39 AM
le 05-05-2006 06:44 AM
It sounds like you approached it right and it ought to work. I can't think of much else to suggest except general troubleshooting. For example, can you try configuring and wiring to use Ctr3 Out instead of Ctr2? It looks like PFI24 / DIO24 is similarly unused.
When does Ctr2 reset? Is it when you first start the DIO task? How have you specified your DIO virtual channel(s)? Can you post your code -- when I get a chance I can try to replicate the problem.
-Kevin P.
le 05-05-2006 07:30 AM
Ok, so i write a little step by step .....
First 1 call the example VI "Gen Dig Pulse Train-Continous.vi" and select ctr0 and start the VI.
Second I start the "test_DO.vi" (see Atachment) and start this. The Counter ctr0 will work fine.
If I do this with ctr2, the signal stops, wenn I wirte to DIO.
le 05-05-2006 03:11 PM
I wasn't able to replicate the problem. On my system, Ctr2 continued running just like Ctr0. Tough to guess what's going on with your system...
-Kevin P.
le 05-08-2006 03:04 AM
le 05-11-2006 01:35 AM
