Continuous Integration
Teststand in docker container - unable to instantiate Engine class
I wonder if this might have to do with the switch to .net 8.... since TS2024
Message 11 of 12
(194 Views)
Seems it si not related to activation window
Trace from 2019 in docker:
************* Preparing the environment for Debugger Extensions Gallery repositories **************
   ExtensionRepository : Implicit
   UseExperimentalFeatureForNugetShare : true
   AllowNugetExeUpdate : true
   NonInteractiveNuget : true
   AllowNugetMSCredentialProviderInstall : true
   AllowParallelInitializationOfLocalRepositories : true
   EnableRedirectToV8JsProvider : false
   -- Configuring repositories
      ----> Repository : LocalInstalled, Enabled: true
      ----> Repository : UserExtensions, Enabled: true
>>>>>>>>>>>>> Preparing the environment for Debugger Extensions Gallery repositories completed, duration 0.000 seconds
************* Waiting for Debugger Extensions Gallery to Initialize **************
>>>>>>>>>>>>> Waiting for Debugger Extensions Gallery to Initialize completed, duration 0.016 seconds
   ----> Repository : UserExtensions, Enabled: true, Packages count: 0
   ----> Repository : LocalInstalled, Enabled: true, Packages count: 29
Microsoft (R) Windows Debugger Version 10.0.26100.4654 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
CommandLine: powershell.exe -File C:\docker\test2019.PS1
************* Path validation summary **************
Response                         Time (ms)     Location
Deferred                                       srv*
Symbol search path is: srv*
Executable search path is:
| This target supports Hardware-enforced Stack Protection. A HW based    |
| "Shadow Stack" may be available to assist in debugging and analysis.   |
| See aka.ms/userhsp for more info.                                      |
| dps        |
ModLoad: 00007ff6`b3980000 00007ff6`b39ee000   powershell.exe
ModLoad: 00007ffc`888a0000 00007ffc`88aa1000   ntdll.dll
ModLoad: 00007ffc`85d60000 00007ffc`85e1c000   C:\Windows\System32\KERNEL32.DLL
ModLoad: 00007ffc`855a0000 00007ffc`85910000   C:\Windows\System32\KERNELBASE.dll
ModLoad: 00007ffc`83c40000 00007ffc`83ce3000   C:\Windows\System32\msvcrt.dll
ModLoad: 00007ffc`83830000 00007ffc`83908000   C:\Windows\System32\OLEAUT32.dll
ModLoad: 00007ffc`840a0000 00007ffc`84140000   C:\Windows\System32\msvcp_win.dll
ModLoad: 00007ffc`84860000 00007ffc`84970000   C:\Windows\System32\ucrtbase.dll
ModLoad: 00007ffc`850d0000 00007ffc`85440000   C:\Windows\System32\combase.dll
ModLoad: 00007ffc`84740000 00007ffc`8485e000   C:\Windows\System32\RPCRT4.dll
ModLoad: 00007ffc`83ee0000 00007ffc`83f91000   C:\Windows\System32\ADVAPI32.dll
ModLoad: 00007ffc`854f0000 00007ffc`85592000   C:\Windows\System32\sechost.dll
ModLoad: 00007ffc`83ba0000 00007ffc`83bc7000   C:\Windows\System32\bcrypt.dll
ModLoad: 00007ffc`85910000 00007ffc`85a46000   C:\Windows\System32\OLE32.dll
ModLoad: 00007ffc`7f790000 00007ffc`7f7ae000   C:\Windows\SYSTEM32\ATL.DLL
ModLoad: 00007ffc`84710000 00007ffc`8473c000   C:\Windows\System32\GDI32.dll
ModLoad: 00007ffc`85bb0000 00007ffc`85d55000   C:\Windows\System32\USER32.dll
ModLoad: 00007ffc`87860000 00007ffc`87886000   C:\Windows\System32\win32u.dll
ModLoad: 00007ffc`84180000 00007ffc`8429d000   C:\Windows\System32\gdi32full.dll
ModLoad: 00007ffc`7f570000 00007ffc`7f5d7000   C:\Windows\SYSTEM32\mscoree.dll
(65c.660): Break instruction exception - code 80000003 (first chance)
ntdll!LdrpDoDebuggerBreak+0x30:
00007ffc`88974464 cc              int     3
0:000> cdb: Reading initial command 'g; q'
ModLoad: 00007ffc`7f1e0000 00007ffc`7f28a000   C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscoreei.dll
ModLoad: 00007ffc`83680000 00007ffc`836df000   C:\Windows\System32\SHLWAPI.dll
ModLoad: 00007ffc`81e50000 00007ffc`81e67000   C:\Windows\SYSTEM32\kernel.appcore.dll
ModLoad: 00007ffc`80820000 00007ffc`8082a000   C:\Windows\SYSTEM32\VERSION.dll
ModLoad: 00007ffc`7e130000 00007ffc`7ec65000   C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clr.dll
ModLoad: 00007ffc`7df50000 00007ffc`7e00d000   C:\Windows\SYSTEM32\ucrtbase_clr0400.dll
ModLoad: 00007ffc`7f480000 00007ffc`7f496000   C:\Windows\SYSTEM32\VCRUNTIME140_CLR0400.dll
(65c.660): Unknown exception - code 04242420 (first chance)
ModLoad: 00007ffc`83fa0000 00007ffc`83fa8000   C:\Windows\System32\psapi.dll
ModLoad: 00007ffc`7c740000 00007ffc`7dd9d000   C:\Windows\assembly\NativeImages_v4.0.30319_64\mscorlib\7d22799b3d3a7d027fd7cb0256e7ca4f\mscorlib.ni.dll
ModLoad: 00007ffc`834a0000 00007ffc`8351f000   C:\Windows\System32\bcryptPrimitives.dll
ModLoad: 000001b6`06420000 000001b6`06456000   Microsoft.PowerShell.ConsoleHost.dll
ModLoad: 000001b6`06590000 000001b6`065c6000   Microsoft.PowerShell.ConsoleHost.dll
ModLoad: 00007ffc`82d30000 00007ffc`82d4b000   C:\Windows\SYSTEM32\CRYPTSP.dll
ModLoad: 00007ffc`826a0000 00007ffc`826d8000   C:\Windows\system32\rsaenh.dll
ModLoad: 00007ffc`82d50000 00007ffc`82d5c000   C:\Windows\SYSTEM32\CRYPTBASE.dll
ModLoad: 00007ffc`7c400000 00007ffc`7c54f000   C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clrjit.dll
ModLoad: 000001b6`1e700000 000001b6`1ed34000   System.Management.Automation.dll
ModLoad: 000001b6`1ed40000 000001b6`1f374000   System.Management.Automation.dll
ModLoad: 000001b6`1e610000 000001b6`1e676000   System.Configuration.dll
ModLoad: 000001b6`1e680000 000001b6`1e6e6000   System.Configuration.dll
ModLoad: 00007ffc`7b2b0000 00007ffc`7bf27000   C:\Windows\assembly\NativeImages_v4.0.30319_64\System\846723d766c4af6b08500c6b9b6c9425\System.ni.dll
ModLoad: 000001b6`1e610000 000001b6`1e660000   System.Security.dll
ModLoad: 000001b6`1e660000 000001b6`1e6b0000   System.Security.dll
ModLoad: 00007ffc`7a7f0000 00007ffc`7b264000   C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Core\760c8058bd380aed658179621a9e099a\System.Core.ni.dll
ModLoad: 00007ffc`83990000 00007ffc`83a3f000   C:\Windows\System32\clbcatq.dll
ModLoad: 00007ffc`84970000 00007ffc`850ca000   C:\Windows\System32\shell32.dll
ModLoad: 00007ffc`80e60000 00007ffc`816a3000   C:\Windows\SYSTEM32\windows.storage.dll
ModLoad: 00007ffc`83fb0000 00007ffc`8409a000   C:\Windows\System32\SHCORE.dll
ModLoad: 00007ffc`83520000 00007ffc`83596000   C:\Windows\System32\wintrust.dll
ModLoad: 00007ffc`83340000 00007ffc`834a0000   C:\Windows\System32\CRYPT32.dll
ModLoad: 00007ffc`83010000 00007ffc`83022000   C:\Windows\SYSTEM32\MSASN1.dll
ModLoad: 00007ffc`7a7c0000 00007ffc`7a7e3000   C:\Windows\SYSTEM32\amsi.dll
ModLoad: 000001b6`1e800000 000001b6`1ea86000   System.Xml.dll
ModLoad: 000001b6`1ea90000 000001b6`1ed16000   System.Xml.dll
ModLoad: 000001b6`1e680000 000001b6`1e6a4000   Microsoft.Management.Infrastructure.dll
ModLoad: 000001b6`1e6b0000 000001b6`1e6d4000   Microsoft.Management.Infrastructure.dll
ModLoad: 000001b6`1e800000 000001b6`1e822000   System.Numerics.dll
ModLoad: 00007ffc`82b70000 00007ffc`82b95000   C:\Windows\SYSTEM32\gpapi.dll
ModLoad: 00007ffc`82de0000 00007ffc`82e20000   C:\Windows\SYSTEM32\wldp.dll
ModLoad: 000001b6`1e830000 000001b6`1e852000   System.Numerics.dll
ModLoad: 000001b6`1e860000 000001b6`1e8c8000   System.DirectoryServices.dll
ModLoad: 000001b6`1e8d0000 000001b6`1e938000   System.DirectoryServices.dll
ModLoad: 000001b6`1e860000 000001b6`1e8c6000   System.Management.dll
ModLoad: 000001b6`1e940000 000001b6`1e9a6000   System.Management.dll
ModLoad: 00007ffc`77bb0000 00007ffc`77bc6000   C:\Windows\System32\MSISIP.DLL
ModLoad: 00007ffc`77b90000 00007ffc`77baa000   C:\Windows\System32\wshext.dll
ModLoad: 00007ffc`77070000 00007ffc`770ba000   C:\Windows\System32\AppxSip.dll
onecore\printscan\appxpackaging\signing\src\appxsip.cpp(603)\AppxSip.dll!00007FFC77071710: (caller: 00007FFC83345906) ReturnHr(1) tid(660) 80070032 The request is not supported.
onecore\printscan\appxpackaging\signing\src\appxbundlesip.cpp(691)\AppxSip.dll!00007FFC77071327: (caller: 00007FFC83345906) ReturnHr(2) tid(660) 80070032 The request is not supported.
ModLoad: 00007ffc`7a230000 00007ffc`7a23c000   C:\Windows\System32\WindowsPowerShell\v1.0\pwrshsip.dll
ModLoad: 00007ffc`79e90000 00007ffc`7a1fc000   System.Data.dll
ModLoad: 000001b6`1f4d0000 000001b6`1f83c000   System.Data.dll
ModLoad: 00007ffc`79b20000 00007ffc`79e8c000   C:\Windows\Microsoft.Net\assembly\GAC_64\System.Data\v4.0_4.0.0.0__b77a5c561934e089\System.Data.dll
ModLoad: 00007ffc`83910000 00007ffc`83981000   C:\Windows\System32\WS2_32.dll
(65c.660): C++ EH exception - code e06d7363 (first chance)
ModLoad: 000001b6`1e860000 000001b6`1e8c6000   System.Configuration.dll
ModLoad: 000001b6`1e9b0000 000001b6`1ea16000   System.Configuration.dll
ModLoad: 00007ffc`83b70000 00007ffc`83b91000   C:\Windows\SYSTEM32\profapi.dll
ModLoad: 000001b6`065e0000 000001b6`065fe000   Microsoft.PowerShell.Security.dll
ModLoad: 000001b6`1e800000 000001b6`1e81e000   Microsoft.PowerShell.Security.dll
ModLoad: 00007ffc`79ad0000 00007ffc`79b1f000   System.Transactions.dll
ModLoad: 000001b6`1e860000 000001b6`1e8af000   System.Transactions.dll
ModLoad: 00007ffc`79a80000 00007ffc`79acf000   C:\Windows\Microsoft.Net\assembly\GAC_64\System.Transactions\v4.0_4.0.0.0__b77a5c561934e089\System.Transactions.dll
ModLoad: 00007ffc`81c30000 00007ffc`81c3c000   C:\Windows\SYSTEM32\secur32.dll
ModLoad: 00007ffc`82f80000 00007ffc`82fca000   C:\Windows\SYSTEM32\SSPICLI.DLL
onecore\printscan\appxpackaging\signing\src\appxsip.cpp(603)\AppxSip.dll!00007FFC77071710: (caller: 00007FFC83345906) ReturnHr(3) tid(2c4) 80070032 The request is not supported.
onecore\printscan\appxpackaging\signing\src\appxbundlesip.cpp(691)\AppxSip.dll!00007FFC77071327: (caller: 00007FFC83345906) ReturnHr(4) tid(2c4) 80070032 The request is not supported.
ModLoad: 00007ffc`79880000 00007ffc`79a73000   C:\Windows\SYSTEM32\urlmon.dll
ModLoad: 00007ffc`79590000 00007ffc`79846000   C:\Windows\SYSTEM32\iertutil.dll
ModLoad: 00007ffc`79850000 00007ffc`79878000   C:\Windows\SYSTEM32\srvcli.dll
ModLoad: 00007ffc`828e0000 00007ffc`828ec000   C:\Windows\SYSTEM32\netutils.dll
ModLoad: 00007ffc`7dda0000 00007ffc`7dea0000   C:\Windows\SYSTEM32\PROPSYS.dll
ModLoad: 00007ffc`79570000 00007ffc`79583000   C:\Windows\SYSTEM32\virtdisk.dll
ModLoad: 00007ffc`79560000 00007ffc`7956b000   C:\Windows\SYSTEM32\FLTLIB.DLL
ModLoad: 000001b6`1f840000 000001b6`1f88a000   image000001b6`1f840000
ModLoad: 000001b6`1f890000 000001b6`1f8da000   image000001b6`1f890000
ModLoad: 000001b6`1f8e0000 000001b6`1f92a000   image000001b6`1f8e0000
(65c.2c4): CLR exception - code e0434352 (first chance)
ModLoad: 000001b6`1ff80000 000001b6`205fa000   Microsoft.PowerShell.Commands.Utility.dll
ModLoad: 000001b6`20600000 000001b6`20c7a000   Microsoft.PowerShell.Commands.Utility.dll
ModLoad: 000001b6`065e0000 000001b6`065fa000   System.Configuration.Install.dll
ModLoad: 000001b6`1e8b0000 000001b6`1e8ca000   System.Configuration.Install.dll
ModLoad: 00007ffc`76ea0000 00007ffc`77062000   C:\Program Files\National Instruments\TestStand 2019\Bin\teapi.dll
ModLoad: 00007ffc`76a40000 00007ffc`76e9e000   C:\Program Files\National Instruments\TestStand 2019\Bin\tefwk.dll
ModLoad: 00007ffc`78dd0000 00007ffc`78e6d000   C:\Windows\SYSTEM32\MSVCP140.dll
ModLoad: 00007ffc`75880000 00007ffc`76a34000   C:\Program Files\National Instruments\TestStand 2019\Bin\TSEngine.dll
ModLoad: 00007ffc`86700000 00007ffc`86717000   C:\Windows\SYSTEM32\VCRUNTIME140.dll
ModLoad: 00007ffc`757d0000 00007ffc`75876000   C:\Program Files\National Instruments\TestStand 2019\Bin\tsuiutil.dll
ModLoad: 00007ffc`85a90000 00007ffc`85b73000   C:\Windows\System32\COMDLG32.dll
ModLoad: 00007ffc`75200000 00007ffc`757cc000   C:\Windows\SYSTEM32\mfc140.dll
ModLoad: 00007ffc`84140000 00007ffc`84171000   C:\Windows\System32\IMM32.dll
ModLoad: 00007ffc`75140000 00007ffc`751f2000   C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.20348.3804_none_377acab5165a97ad\COMCTL32.dll
ModLoad: 000001b6`1f930000 000001b6`1f9e2000   C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.20348.3804_none_377acab5165a97ad\COMCTL32.dll
ModLoad: 00007ffc`75090000 00007ffc`75133000   C:\Windows\SYSTEM32\UxTheme.dll
ModLoad: 00007ffc`749c0000 00007ffc`75084000   C:\Windows\SYSTEM32\cvirte.dll
ModLoad: 00007ffc`785f0000 00007ffc`78617000   C:\Windows\SYSTEM32\WINMM.dll
ModLoad: 00007ffc`81c90000 00007ffc`81cad000   C:\Windows\SYSTEM32\MPR.dll
ModLoad: 00007ffc`77b80000 00007ffc`77b87000   C:\Windows\SYSTEM32\MSIMG32.dll
ModLoad: 00007ffc`74920000 00007ffc`749bb000   C:\Windows\SYSTEM32\WINSPOOL.DRV
ModLoad: 00007ffc`81f70000 00007ffc`81f9f000   C:\Windows\SYSTEM32\dwmapi.dll
ModLoad: 00007ffc`74870000 00007ffc`7491f000   C:\Windows\SYSTEM32\mscms.dll
ModLoad: 00007ffc`74850000 00007ffc`74863000   C:\Windows\SYSTEM32\ColorAdapterClient.dll
ModLoad: 00007ffc`74840000 00007ffc`74847000   C:\Windows\SYSTEM32\RICHED32.DLL
ModLoad: 00007ffc`747a0000 00007ffc`74840000   C:\Windows\SYSTEM32\RICHED20.dll
ModLoad: 00007ffc`74780000 00007ffc`74799000   C:\Windows\SYSTEM32\USP10.dll
ModLoad: 00007ffc`74740000 00007ffc`7477a000   C:\Windows\SYSTEM32\msls31.dll
(65c.2c4): C++ EH exception - code e06d7363 (first chance)
ModLoad: 00007ffc`81c40000 00007ffc`81c74000   C:\Windows\SYSTEM32\ntmarta.dll
ModLoad: 00007ffc`74620000 00007ffc`7473a000   C:\Program Files\National Instruments\TestStand 2019\Bin\AutomationAdp.dll
ModLoad: 00007ffc`74420000 00007ffc`74613000   C:\Program Files\National Instruments\TestStand 2019\Bin\BLVAdapter.dll
ModLoad: 00007ffc`74360000 00007ffc`74414000   C:\Program Files\National Instruments\TestStand 2019\Bin\cppAdp.dll
ModLoad: 00007ffc`741f0000 00007ffc`7435f000   C:\Program Files\National Instruments\TestStand 2019\Bin\CAdapterShared.dll
ModLoad: 00007ffc`7ef10000 00007ffc`7f130000   C:\Windows\SYSTEM32\dbghelp.dll
ModLoad: 00007ffc`74190000 00007ffc`741f0000   C:\Program Files\National Instruments\TestStand 2019\Bin\VSIntegration.dll
ModLoad: 00000000`5ac20000 00000000`5acad000   C:\Windows\SYSTEM32\cviauto.dll
ModLoad: 00000000`00400000 00000000`00461000   C:\Windows\SYSTEM32\cvidbgi.dll
@{module_attach|0000000000400000|  1|  2|  3|  4|00000000004308AB| 18|C:\Windows\SYSTEM32\cvidbgi.dll:15|32|36|40|44|48|65|69}@ModLoad: 00007ffc`74080000 00007ffc`7418a000   C:\Program Files\National Instruments\TestStand 2019\Bin\DotNetAdp.dll
ModLoad: 00007ffc`73d80000 00007ffc`7407e000   C:\Program Files\National Instruments\TestStand 2019\Bin\FlexGAdapter.dll
ModLoad: 00007ffc`73ca0000 00007ffc`73d78000   C:\Program Files\National Instruments\TestStand 2019\Bin\flxCVIadp.dll
ModLoad: 00007ffc`73c00000 00007ffc`73c94000   C:\Program Files\National Instruments\TestStand 2019\Bin\DotNetAdapterManagedSupport.dll
ModLoad: 00007ffc`73b90000 00007ffc`73bf3000   C:\Program Files\National Instruments\TestStand 2019\Bin\HTBasicAdapter.dll
ModLoad: 00007ffc`73b50000 00007ffc`73b90000   C:\Program Files\National Instruments\TestStand 2019\Bin\noneAdp.dll
ModLoad: 00007ffc`73a80000 00007ffc`73b46000   C:\Program Files\National Instruments\TestStand 2019\Bin\PythonAdapter.dll
ModLoad: 00007ffc`739b0000 00007ffc`73a71000   C:\Program Files\National Instruments\TestStand 2019\Bin\seqadp.dll
ModLoad: 00007ffc`73980000 00007ffc`739a1000   C:\Program Files\National Instruments\TestStand 2019\Bin\nizlibwapi.dll
ModLoad: 00007ffc`73940000 00007ffc`7397a000   C:\Program Files\National Instruments\Shared\NIPythonInterface\niPythonInterface.dll
ModLoad: 00007ffc`73600000 00007ffc`7368b000   C:\Windows\SYSTEM32\nierInterface.dll
ModLoad: 00007ffc`7ed40000 00007ffc`7ed70000   C:\Windows\SYSTEM32\dbgcore.DLL
ModLoad: 00007ffc`836e0000 00007ffc`83784000   C:\Windows\SYSTEM32\sxs.dll
ModLoad: 000001b6`1fa90000 000001b6`1fa9a000   image000001b6`1fa90000
ModLoad: 000001b6`1fa80000 000001b6`1fa8a000   image000001b6`1fa80000
ModLoad: 00007ffc`73900000 00007ffc`7393c000   C:\Program Files\National Instruments\TestStand 2019\Bin\ManagedSupport.dll
ModLoad: 00007ffc`738c0000 00007ffc`738fc000   ManagedSupport.dll
ModLoad: 000001b6`1fc80000 000001b6`1fcbc000   ManagedSupport.dll
ModLoad: 00007ffc`73350000 00007ffc`735f8000   zNationalInstruments.TestStand.DotNetAdapterGAC.dll
ModLoad: 000001b6`22620000 000001b6`228c8000   zNationalInstruments.TestStand.DotNetAdapterGAC.dll
ModLoad: 00007ffc`730a0000 00007ffc`73348000   C:\Windows\Microsoft.Net\assembly\GAC_64\zNationalInstruments.TestStand.DotNetAdapterGAC\v4.0_19.0.0.170__ad9244eb3b825cd8\zNationalInstruments.TestStand.DotNetAdapterGAC.dll
Globals                                      : System.__ComObject
CurrentUser                                  :
ApplicationIsEditor                          : False
AppMainHwnd                                  : 0
NumAdapters                                  : 10
DefaultAdapter                               : G Flexible VI Adapter
EnableUserPrivilegeChecking                  : True
AutoLoginSystemUser                          : False
MajorVersion                                 : 19
MinorVersion                                 : 0
RevisionVersion                              : 0
VersionString                                : 2019 f4 (19.0.0.170) 64-bit
EnableRemote                                 : False
ConfigDirectory                              : C:\ProgramData\National Instruments\TestStand 2019 (64-bit)\Cfg
BinDirectory                                 : C:\Program Files\National Instruments\TestStand 2019\Bin
TestStandDirectory                           : C:\Program Files\National Instruments\TestStand 2019
StepTypes                                    :
CustomDataTypes                              :
BuiltinDataTypes                             :
TracingEnabled                               : True
BreakpointsEnabled                           : True
DisableResults                               : False
AlwaysGotoCleanupOnFailure                   : False
BreakOnRTE                                   : True
ExecutionMask                                : 61469
UIMessagePollingEnabled                      : False
IsUIMessageQueueEmpty                        : True
UIMessageDelay                               : 0
UIMessageMinDelay                            : 0
IsRemote                                     : False
MasterEngine                                 :
UseLocalizedDecimalPoint                     : False
GlobalsFile                                  : System.__ComObject
UsersFile                                    : System.__ComObject
ConfigFile                                   : System.__ComObject
SmallImageList                               :
LargeImageList                               :
DefaultAdapterIndex                          : 0
CurrentWorkspaceFile                         :
SecondsSinceStart                            : 2.36795860000001
CheckOutFilesWhenEdited                      : True
CheckOutOnlySelectedFiles                    : False
LastWorkspacePath                            :
PromptWhenAddingFilesToSC                    : True
ReloadDocsWhenOpeningWorkspace               : False
ReloadWorkspaceAtStartup                     : False
UseDialogForCheckOut                         : True
ShowHiddenProperties                         : False
ComputerName                                 : 2C89D8A0B327
UniqueEngineId                               : {87633DB2-71DF-11F0-B252-9F13CC315B8D}
CVIAdapter_ExternalCVIPrj                    : AdapterSupport\CVI\tscvirun.prj
CVIAdapter_ExecuteStepsInCVI                 : False
RequireUserLogin                             : False
FileDialogDirHistoryList                     : {C:\Users\Public\Documents\National Instruments\TestStand 2019 (64-bit), C:\Program Files\National Instruments\TestStand 2019}
StationID                                    : 2C89D8A0B327
NumImages                                    : 454
SeqFileVersionAutoIncrementOpt               : FileVersionInc_None
TemporaryGlobals                             : System.__ComObject
RTEOption                                    : RTEOption_ShowDialog
SecondsSince1970UniversalCoordinatedTime     : 1754386533.534
StationModelSequenceFilePath                 : SequentialModel.seq
SearchDirectories                            : System.__ComObject
ExternalReportViewers                        : System.__ComObject
StationOptions                               : System.__ComObject
Images                                       : System.__ComObject
WatchExpressionsEnabled                      : False
LicenseType                                  : LicenseType_NoLicense
PersistBreakpoints                           : False
PersistWatchExpressions                      : False
PersistConfigFile                            : True
OutputMessagesEnabled                        : True
ApplicationLicense                           : ApplicationLicense_Unspecified
UndoLimit                                    : -1
Utility                                      : System.__ComObject
DotNetGarbageCollectionInterval              : -1
SecondsAtStartIn1970UniversalCoordinatedTime : 1754386531.16281
DotNetCLRVersion                             : 4.0.30319.42000
BuildVersion                                 : 170
SmallImageListEx                             : 1881747685520
LargeImageListEx                             : 1881747844112
Is64Bit                                      : True
ProfilingEnabled                             : False
ProfilerOptions                              : 0
ProfilerOutputMessageCategoryName            : NI Data - Profiler
ProfilerInputOutputCaptureMaximumTextLength  : -1
ModLoad: 00007ffc`73820000 00007ffc`738be000   C:\Windows\SYSTEM32\TextShaping.dll
and from 2025 where it hangs:
| dps        |
ModLoad: 00007ff6`01ad0000 00007ff6`01b3e000   powershell.exe
ModLoad: 00007ffc`85870000 00007ffc`85be0000   C:\Windows\System32\KERNELBASE.dll
ModLoad: 00007ffc`85560000 00007ffc`85603000   C:\Windows\System32\msvcrt.dll
ModLoad: 00007ffc`85c80000 00007ffc`85d58000   C:\Windows\System32\OLEAUT32.dll
ModLoad: 00007ffc`84b80000 00007ffc`84c20000   C:\Windows\System32\msvcp_win.dll
ModLoad: 00007ffc`85030000 00007ffc`85140000   C:\Windows\System32\ucrtbase.dll
ModLoad: 00007ffc`851f0000 00007ffc`85560000   C:\Windows\System32\combase.dll
ModLoad: 00007ffc`80be0000 00007ffc`80bfe000   C:\Windows\SYSTEM32\ATL.DLL
ModLoad: 00007ffc`84f10000 00007ffc`8502e000   C:\Windows\System32\RPCRT4.dll
ModLoad: 00007ffc`849d0000 00007ffc`84b75000   C:\Windows\System32\USER32.dll
ModLoad: 00007ffc`84910000 00007ffc`849c1000   C:\Windows\System32\ADVAPI32.dll
ModLoad: 00007ffc`85140000 00007ffc`851e2000   C:\Windows\System32\sechost.dll
ModLoad: 00007ffc`84ee0000 00007ffc`84f0c000   C:\Windows\System32\GDI32.dll
ModLoad: 00007ffc`84310000 00007ffc`84337000   C:\Windows\System32\bcrypt.dll
ModLoad: 00007ffc`84d10000 00007ffc`84e2d000   C:\Windows\System32\gdi32full.dll
ModLoad: 00007ffc`85670000 00007ffc`857a6000   C:\Windows\System32\OLE32.dll
ModLoad: 00007ffc`7f0a0000 00007ffc`7f107000   C:\Windows\SYSTEM32\mscoree.dll
(690.4a0): Break instruction exception - code 80000003 (first chance)
ModLoad: 00007ffc`7ed80000 00007ffc`7ee2a000   C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscoreei.dll
ModLoad: 00007ffc`84340000 00007ffc`8439f000   C:\Windows\System32\SHLWAPI.dll
ModLoad: 00007ffc`7fc10000 00007ffc`7fc1a000   C:\Windows\SYSTEM32\VERSION.dll
ModLoad: 00007ffc`7def0000 00007ffc`7ea25000   C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clr.dll
ModLoad: 00007ffc`7fbf0000 00007ffc`7fc06000   C:\Windows\SYSTEM32\VCRUNTIME140_CLR0400.dll
ModLoad: 00007ffc`7de30000 00007ffc`7deed000   C:\Windows\SYSTEM32\ucrtbase_clr0400.dll
(690.4a0): Unknown exception - code 04242420 (first chance)
ModLoad: 00007ffc`85630000 00007ffc`85638000   C:\Windows\System32\psapi.dll
ModLoad: 00007ffc`7c560000 00007ffc`7dbbd000   C:\Windows\assembly\NativeImages_v4.0.30319_64\mscorlib\7d22799b3d3a7d027fd7cb0256e7ca4f\mscorlib.ni.dll
ModLoad: 00007ffc`83520000 00007ffc`8359f000   C:\Windows\System32\bcryptPrimitives.dll
ModLoad: 00000165`f82d0000 00000165`f8306000   Microsoft.PowerShell.ConsoleHost.dll
ModLoad: 00000165`f8720000 00000165`f8756000   Microsoft.PowerShell.ConsoleHost.dll
ModLoad: 00007ffc`7c280000 00007ffc`7c3cf000   C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clrjit.dll
ModLoad: 00000165`f8cf0000 00000165`f9324000   System.Management.Automation.dll
ModLoad: 00000165`f9330000 00000165`f9964000   System.Management.Automation.dll
ModLoad: 00007ffc`7b260000 00007ffc`7bed7000   C:\Windows\assembly\NativeImages_v4.0.30319_64\System\846723d766c4af6b08500c6b9b6c9425\System.ni.dll
ModLoad: 00007ffc`7a7e0000 00007ffc`7b254000   C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Core\760c8058bd380aed658179621a9e099a\System.Core.ni.dll
ModLoad: 00007ffc`84e30000 00007ffc`84edf000   C:\Windows\System32\clbcatq.dll
ModLoad: 00007ffc`83b80000 00007ffc`842da000   C:\Windows\System32\shell32.dll
ModLoad: 00007ffc`80d30000 00007ffc`81573000   C:\Windows\SYSTEM32\windows.storage.dll
ModLoad: 00007ffc`83a30000 00007ffc`83b1a000   C:\Windows\System32\SHCORE.dll
ModLoad: 00007ffc`79b80000 00007ffc`7a42c000   C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Xml\907ab2a21f651819276108145cff1b72\System.Xml.ni.dll
ModLoad: 00007ffc`83340000 00007ffc`833b6000   C:\Windows\System32\wintrust.dll
ModLoad: 00007ffc`833c0000 00007ffc`83520000   C:\Windows\System32\CRYPT32.dll
ModLoad: 00007ffc`7a790000 00007ffc`7a7b3000   C:\Windows\SYSTEM32\amsi.dll
ModLoad: 00000165`f8810000 00000165`f8834000   Microsoft.Management.Infrastructure.dll
ModLoad: 00000165`f8840000 00000165`f8864000   Microsoft.Management.Infrastructure.dll
ModLoad: 00000165`f8df0000 00000165`f8e12000   System.Numerics.dll
ModLoad: 00000165`f8e20000 00000165`f8e42000   System.Numerics.dll
ModLoad: 00007ffc`7a620000 00007ffc`7a788000   C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Dired13b18a9#\2437abcd58b5d1164a37baaa7fadc692\System.DirectoryServices.ni.dll
ModLoad: 00007ffc`7a450000 00007ffc`7a5b6000   C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Management\1fddd88734fc96bfa3dd1de455c7a0dc\System.Management.ni.dll
ModLoad: 00007ffc`75840000 00007ffc`75856000   C:\Windows\System32\MSISIP.DLL
ModLoad: 00007ffc`74df0000 00007ffc`74e0a000   C:\Windows\System32\wshext.dll
ModLoad: 00007ffc`74da0000 00007ffc`74dea000   C:\Windows\System32\AppxSip.dll
onecore\printscan\appxpackaging\signing\src\appxsip.cpp(603)\AppxSip.dll!00007FFC74DA1710: (caller: 00007FFC833C5906) ReturnHr(1) tid(4a0) 80070032 The request is not supported.
onecore\printscan\appxpackaging\signing\src\appxbundlesip.cpp(691)\AppxSip.dll!00007FFC74DA1327: (caller: 00007FFC833C5906) ReturnHr(2) tid(4a0) 80070032 The request is not supported.
ModLoad: 00007ffc`74d90000 00007ffc`74d9c000   C:\Windows\System32\WindowsPowerShell\v1.0\pwrshsip.dll
ModLoad: 00007ffc`78ca0000 00007ffc`79619000   C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Data\da4396d159361c0b44714f851a5ae292\System.Data.ni.dll
ModLoad: 00007ffc`78930000 00007ffc`78c9c000   C:\Windows\Microsoft.Net\assembly\GAC_64\System.Data\v4.0_4.0.0.0__b77a5c561934e089\System.Data.dll
ModLoad: 00007ffc`85c00000 00007ffc`85c71000   C:\Windows\System32\WS2_32.dll
(690.47c): C++ EH exception - code e06d7363 (first chance)
ModLoad: 00007ffc`787f0000 00007ffc`78923000   C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Configuration\1d96ca250787406b471e668853fbe6d7\System.Configuration.ni.dll
ModLoad: 00007ffc`842e0000 00007ffc`84301000   C:\Windows\SYSTEM32\profapi.dll
ModLoad: 00000165`f8810000 00000165`f882e000   Microsoft.PowerShell.Security.dll
ModLoad: 00000165`f8df0000 00000165`f8e0e000   Microsoft.PowerShell.Security.dll
ModLoad: 00007ffc`78710000 00007ffc`787eb000   C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Transactions\e3831778163332aeb1f414c6205545f5\System.Transactions.ni.dll
ModLoad: 00007ffc`78680000 00007ffc`786cf000   C:\Windows\Microsoft.Net\assembly\GAC_64\System.Transactions\v4.0_4.0.0.0__b77a5c561934e089\System.Transactions.dll
ModLoad: 00007ffc`82fc0000 00007ffc`8300a000   C:\Windows\SYSTEM32\SSPICLI.DLL
onecore\printscan\appxpackaging\signing\src\appxsip.cpp(603)\AppxSip.dll!00007FFC74DA1710: (caller: 00007FFC833C5906) ReturnHr(3) tid(6e4) 80070032 The request is not supported.
onecore\printscan\appxpackaging\signing\src\appxbundlesip.cpp(691)\AppxSip.dll!00007FFC74DA1327: (caller: 00007FFC833C5906) ReturnHr(4) tid(6e4) 80070032 The request is not supported.
ModLoad: 00007ffc`78480000 00007ffc`78673000   C:\Windows\SYSTEM32\urlmon.dll
ModLoad: 00007ffc`781c0000 00007ffc`78476000   C:\Windows\SYSTEM32\iertutil.dll
ModLoad: 00007ffc`7a5c0000 00007ffc`7a5e8000   C:\Windows\SYSTEM32\srvcli.dll
ModLoad: 00007ffc`7dbc0000 00007ffc`7dcc0000   C:\Windows\SYSTEM32\PROPSYS.dll
ModLoad: 00007ffc`7a430000 00007ffc`7a443000   C:\Windows\SYSTEM32\virtdisk.dll
ModLoad: 00007ffc`78700000 00007ffc`7870b000   C:\Windows\SYSTEM32\FLTLIB.DLL
ModLoad: 00000165`f8e50000 00000165`f8e9c000   image00000165`f8e50000
ModLoad: 00000165`f8ea0000 00000165`f8eec000   image00000165`f8ea0000
(690.6e4): CLR exception - code e0434352 (first chance)
ModLoad: 00000165`f9970000 00000165`f9fea000   Microsoft.PowerShell.Commands.Utility.dll
ModLoad: 00000165`f9ff0000 00000165`fa66a000   Microsoft.PowerShell.Commands.Utility.dll
ModLoad: 00000165`f8e50000 00000165`f8e6a000   System.Configuration.Install.dll
ModLoad: 00000165`f8e70000 00000165`f8e8a000   System.Configuration.Install.dll
ModLoad: 00007ffc`74be0000 00007ffc`74d86000   C:\Program Files\National Instruments\TestStand 2025\Bin\teapi.dll
ModLoad: 00007ffc`74780000 00007ffc`74bd7000   C:\Program Files\National Instruments\TestStand 2025\Bin\tefwk.dll
ModLoad: 00007ffc`73990000 00007ffc`74773000   C:\Program Files\National Instruments\TestStand 2025\Bin\TSEngine.dll
ModLoad: 00007ffc`75eb0000 00007ffc`75f3d000   C:\Windows\SYSTEM32\MSVCP140.dll
ModLoad: 00007ffc`760d0000 00007ffc`760dc000   C:\Windows\SYSTEM32\VCRUNTIME140_1.dll
ModLoad: 00007ffc`760b0000 00007ffc`760ce000   C:\Windows\SYSTEM32\VCRUNTIME140.dll
ModLoad: 00007ffc`738f0000 00007ffc`73984000   C:\Program Files\National Instruments\TestStand 2025\Bin\tsuiutil.dll
ModLoad: 00007ffc`84c20000 00007ffc`84d03000   C:\Windows\System32\COMDLG32.dll
ModLoad: 00007ffc`73380000 00007ffc`738e2000   C:\Windows\SYSTEM32\mfc140.dll
ModLoad: 00007ffc`83b20000 00007ffc`83b51000   C:\Windows\System32\IMM32.dll
ModLoad: 00007ffc`732d0000 00007ffc`73373000   C:\Windows\SYSTEM32\UxTheme.dll
ModLoad: 00007ffc`73260000 00007ffc`732c4000   C:\Program Files\National Instruments\TestStand 2025\Bin\nilmCLRCompatibilityClient.dll
ModLoad: 00007ffc`7fbc0000 00007ffc`7fbd4000   C:\Windows\SYSTEM32\WTSAPI32.dll
ModLoad: 00007ffc`82be0000 00007ffc`82c0e000   C:\Windows\SYSTEM32\USERENV.dll
ModLoad: 00007ffc`731a0000 00007ffc`73252000   C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.20348.3804_none_377acab5165a97ad\COMCTL32.dll
ModLoad: 00000165`f9970000 00000165`f9a22000   C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.20348.3804_none_377acab5165a97ad\COMCTL32.dll
ModLoad: 00000165`f9a30000 00000165`f9ae2000   C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.20348.3804_none_377acab5165a97ad\COMCTL32.dll
ModLoad: 00007ffc`73170000 00007ffc`73191000   C:\Program Files\National Instruments\TestStand 2025\Bin\ijwhost.dll
ModLoad: 00007ffc`72a30000 00007ffc`73166000   C:\Windows\SYSTEM32\cvirte.dll
ModLoad: 00007ffc`76430000 00007ffc`76457000   C:\Windows\SYSTEM32\WINMM.dll
ModLoad: 00007ffc`81c80000 00007ffc`81c9d000   C:\Windows\SYSTEM32\MPR.dll
ModLoad: 00007ffc`72990000 00007ffc`72a2b000   C:\Windows\SYSTEM32\WINSPOOL.DRV
ModLoad: 00007ffc`72980000 00007ffc`72987000   C:\Windows\SYSTEM32\MSIMG32.dll
ModLoad: 00007ffc`728d0000 00007ffc`7297f000   C:\Windows\SYSTEM32\mscms.dll
ModLoad: 00007ffc`728b0000 00007ffc`728c3000   C:\Windows\SYSTEM32\ColorAdapterClient.dll
ModLoad: 00007ffc`72890000 00007ffc`728ac000   C:\Program Files\National Instruments\TestStand 2025\AdapterSupport\DotNetSupport\x64\nethost.dll
ModLoad: 00007ffc`72830000 00007ffc`7288b000   C:\Program Files\dotnet\host\fxr\8.0.18\hostfxr.dll
ModLoad: 00007ffc`727c0000 00007ffc`72825000   C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.18\hostpolicy.dll
ModLoad: 00007ffc`722d0000 00007ffc`727b2000   C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.18\coreclr.dll
(690.6e4): Unknown exception - code 04242420 (first chance)
ModLoad: 00007ffc`71410000 00007ffc`7209e000   C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.18\System.Private.CoreLib.dll
ModLoad: 00007ffc`71250000 00007ffc`71406000   C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.18\clrjit.dll
ModLoad: 00007ffc`71210000 00007ffc`7124b000   C:\Program Files\National Instruments\TestStand 2025\Bin\ManagedSupport.dll
ModLoad: 00007ffc`70fb0000 00007ffc`71205000   C:\Windows\SYSTEM32\icu.dll
ModLoad: 00000165`f9310000 00000165`f931e000   C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.18\System.Runtime.dll
ModLoad: 00007ffc`70f90000 00007ffc`70fa2000   C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.18\System.Threading.dll
ModLoad: 00000165`f9300000 00000165`f9308000   C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.18\System.Runtime.Extensions.dll
ModLoad: 00007ffc`70f70000 00007ffc`70f85000   C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.18\System.Runtime.InteropServices.dll
ModLoad: 00007ffc`70f60000 00007ffc`70f65000   C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.18\System.Runtime.CompilerServices.VisualC.dll
ModLoad: 00007ffc`70f40000 00007ffc`70f57000   C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.18\System.Collections.NonGeneric.dll
ModLoad: 00000165`f9a90000 00000165`f9adc000   C:\Program Files\National Instruments\TestStand 2025\Bin\NationalInstruments.TestStand.Interop.API.dll
ModLoad: 00000165`f9a70000 00000165`f9a78000   C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.18\System.Runtime.Loader.dll
ModLoad: 00000165`f9ae0000 00000165`f9afe000   C:\Program Files\National Instruments\TestStand 2025\API\DotNet\Assemblies\CurrentVersion\NationalInstruments.TestStand.Interop.AdapterAPI.dll
ModLoad: 00000165`f9b00000 00000165`f9b4c000   C:\Program Files\National Instruments\TestStand 2025\API\DotNet\Assemblies\CurrentVersion\NationalInstruments.TestStand.Interop.API.dll
ModLoad: 00000165`f9b00000 00000165`f9b0e000   C:\Program Files\National Instruments\TestStand 2025\API\DotNet\Assemblies\CurrentVersion\NationalInstruments.TestStand.Interop.SequenceAnalyzer.dll
ModLoad: 00000165`f9b10000 00000165`f9b4e000   C:\Program Files\National Instruments\TestStand 2025\API\DotNet\Assemblies\CurrentVersion\NationalInstruments.TestStand.Interop.UI.AxControls.dll
ModLoad: 00000165`f9b50000 00000165`f9b98000   C:\Program Files\National Instruments\TestStand 2025\API\DotNet\Assemblies\CurrentVersion\NationalInstruments.TestStand.Interop.UI.dll
ModLoad: 00000165`f9ba0000 00000165`f9bae000   C:\Program Files\National Instruments\TestStand 2025\API\DotNet\Assemblies\CurrentVersion\NationalInstruments.TestStand.Interop.UI.Support.dll
ModLoad: 00000165`f9bb0000 00000165`f9bb6000   C:\Program Files\National Instruments\TestStand 2025\API\DotNet\Assemblies\CurrentVersion\NationalInstruments.TestStand.TSInterfaces.dll
ModLoad: 00000165`f9c50000 00000165`f9d8a000   C:\Program Files\National Instruments\TestStand 2025\API\DotNet\Assemblies\CurrentVersion\NationalInstruments.TestStand.Utility.dll
ModLoad: 00000165`f9bc0000 00000165`f9bcc000   C:\Program Files\National Instruments\TestStand 2025\API\DotNet\Assemblies\CurrentVersion\TSSync.Interop.dll
ModLoad: 000001a6`92b80000 000001a6`92f0e000   C:\Program Files\National Instruments\TestStand 2025\Bin\TSDotNetSupport.dll
ModLoad: 00007ffc`70f20000 00007ffc`70f3e000   C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.18\System.Drawing.Primitives.dll
ModLoad: 00007ffc`70230000 00007ffc`70f1d000   C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\8.0.18\System.Windows.Forms.dll
ModLoad: 00007ffc`70210000 00007ffc`70221000   C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.18\System.ComponentModel.Primitives.dll
ModLoad: 00007ffc`6ff30000 00007ffc`7020d000   C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\8.0.18\System.Windows.Forms.Primitives.dll
ModLoad: 00007ffc`6fef0000 00007ffc`6ff2d000   C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.18\System.Collections.dll
ModLoad: 00007ffc`6fd70000 00007ffc`6fee3000   C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\8.0.18\System.Drawing.Common.dll
ModLoad: 00000165`f9be0000 00000165`f9be8000   C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.18\Microsoft.Win32.Primitives.dll
ModLoad: 00007ffc`6fbb0000 00007ffc`6fd64000   C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.20348.3804_none_c55de93d49875c56\gdiplus.dll
ModLoad: 00000165`f9bf0000 00000165`f9bf8000   C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.18\System.Numerics.Vectors.dll
(690.6e4): C++ EH exception - code e06d7363 (first chance)
ModLoad: 00007ffc`6fb10000 00007ffc`6fbae000   C:\Windows\SYSTEM32\TextShaping.dll
it hangs forever on this step:
What is interesting this step is also called in 2019 but after engine is instantiated.
Message 12 of 12
(185 Views)
