Continuous Integration
Preemptively disable internal error dialog
This dialog appears when I open LabVIEW sometimes:
This blocks VI server from starting so LabVIEWCLI and similar tools won't work. After this dialog appears once, this checkbox shows up in the LabVIEW options:
But on a fresh install the option isn't there. Does anyone know how to disable the dialog on a new install of LabVIEW? The only way I can think of would be to find a way to reliably trigger the warning to happen, which I haven't succeeded at.
What would be better is a comprehensive guide to disabling all the similar blocking dialogs.
(3,282 Views)
One of these ini token should help (not sure which one though)
Use the following INI tokens (LabVIEW.ini) to suppress popups and auto-reporting errors:
NIERShowFatalDialog = 0
NIERFatalAutoSend = true
NIERNonFatalAutoSend = true
NIERShowNonFatalDialogOnExit = false
NIERSendDialogClose = true autoerr = 3
DWarnDialog = false
AutoSaveEnabled = false
AllowMultipleInstances = true
promoteDWarnInternals = false
ShowAIVIsInErrorWindow = true
Matthias Baudot | Software Architect | Founder & Owner at STUDIO BODs | DQMH® Consortium Board Member & Trusted Advisor
STUDIO BODs     LabVIEW Champion     Certified Professional Instructor     DQMH Trusted Advisor     DQMH Consortium Board Member     GCentral Sponsor
â–¶ Check out my LabVIEW presentations and videos!
(3,275 Views)
Did the previous reply resolve your issue? If it did, consider marking it as an Accepted Solution – it can be a great help for other users with similar questions.
Thank you!
(3,235 Views)
I want to figure out which key is responsible for this particular dialog then I will post that info and mark that and the config file block as solutions.
(3,226 Views)
DWarnDialog = false
I finally got code that replicates this issue reliably in a short job.
I added all of these keys and still get the dialog I posted originally.
(3,201 Views)
Accepted by topic author avogadro5
DWarnDialog = false
The key for this dialog is "autoerr = 3." It needs to be on its own line in the ini file to work. This article has the same issue.
(3,192 Views)
