04-05-2018 02:52 AM
Hi Ryan,
Two months back, we started LabVIEW Jenkins CI automation. Now currently we running into an issue.
What happening is the the following:
1. I trigger the build and the source update via AccuRev(No problem).
2.Build.bat executes, it is hanging there only until we abort. But it is working fine in the local server.
Yesterday we changed the Jenkins user account, after that it worked fine for two builds and then again the same above issue came back, it is hanging in Jenkins, but it working in the windows server.
I observed that, when I build locally in the server in the the task manager LabVIEW use 25% CPU and 10 lakh kb memory, but when I trigger throw Jenkins at one point CPU % went to 0 and memory is hanging 1 ***** digit KB.
It would be great, if you can help on this. we get stucked her. Please help us.
01-11-2019 04:06 PM
I have a customer that is in writing each instruction line in the autobuild.csv . He is using some FPGA builds and is having issues writing the instruction line.
He has tried various forms of LabVIEW.project<TAB>FPGA Target<TAB>FPGA build
What is the correct way of writing the instruction line when using FPGA builds?
