Like many others, I like the XKCD web comic (xkcd.com). A few years ago, when I first encountered it, I decided I wanted to read the old comics as well, but didn't want to go through every single one in my browser, because there were a couple of hundred of them. So I wrote a VI which parsed the HTML to get the comics (if you watched The Social Network, this was similar to the getting-the-pictures-of-all-the-girls-on-campus scene except without the beer or using words like "wget" or a multi-billion dollar company on the other side ). This is the VI you see here, in a cleaned up form. Now that I had the comics, I was able to read them while on a trans-atlantic flight, which was my basic plan in the first place.
I personally don't like regular expressions, so I went for the simple parsing option: Search for the start of what you're looking for, then search for what comes next. Anything in between is what you're looking for.
Because XKCD comics are made up of three parts (the name, the comic itself and the title text which appears when you hover over the image and which enhances the comic) I then wrote another VI which would display all of these together, which is also included. To stay with the spirit of the challenge, I also used my previous submission to save the value of the control, so that you can continue reading from where you stopped.
I didn't add a lot of error handling, because these VIs do a very specific task at a specific point in a time, so any errors encountered here can usually be managed by the user. I did, however, add a basic example of how such errors can be handled - simply build a list with the relevant details of each error and keep going. In this case, the list is built inside the main VI. In real apps, it would be delegated to a general error logger.
This basic model can be used to download data from any source which serves it, and I actually used a modification of these VIs to download and read comics from other sites as well.
Retroactively, I realize that I probably don't strictly meet the first challenge rule, but since I can't ask either of my grandmas, I guess it will have to stand.
To have fun.
Luckily, my original submission already complied with the basic requirements for the second round, so it only has two singnificant modifications:
Communication method details:
This submission uses files to transfer data from one program to the other. In this case, the use of files is the most natural choice for the task (saving images and other data for later viewing) since the images are already in that format and that format is easily readable, so there weren't really any other contenders in this case.
That said, here are some advantages of this method:
All that said, I very rarely use files as a real time communication method. I would only use it like that in cases like the one I described above, where there's something that can't really communicate using other methods. In most cases, it would be used as a way to save data, as it is used here.
The VIs should work in any version of LV and on any operating system, as they use native LV functionality. It also uses some OpenG VIs, but those are included as copies in the file, so anyone can use it, whether they have OpenG installed or not.
Main Front Panel (of the viewer):
Main Block Diagram (of the viewer):
Main Block Diagram (of the downloader):
Love it! You just saved me many clicks my friend.
