The attached VI can be used in place of VIAn Run.vi for users of the VI Analyzer API. The only difference is that the attached VI has an 'App for Analysis' input that allows you to specify the Application Instance in which you want the analysis to run. This VI can be useful for doing a programmatic analysis on VIs that reside under an RT or FPGA target in the project.
The VI is saved in LabVIEW 2020. Also note that this VI is not officially supported by NI.
