The attached VI allows you to populate a column in a Multicolumn Listbox with path values, and have the paths be truncated with "..." in the middle of the path so that the beginning and the end of the path are always visible in the column.
The VIs are saved in LabVIEW 2012.
Instructions:
1. Detach the VIs below to the same folder.
2. Open and run test_mcl_truncate.vi. This VI allows you to populate a listbox with a folder list and see how Truncate Paths in Multicolumn Listbox.vi operates.
Testing comment notification
test 2
