Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
Community Documents
NEW! Timer Session
WARNING! Before installing the newest version please remove the old version. Otherwise two versions might install side-by-side.
Overview
This tool allows users to easily create multiple timers for controlling the timing of their code, measuring or benchmarking.
By Reference ExampleBy Reference Example
Timer APITimer API
Calculator HelpersCalculator Helpers
Requirements
Created by Piotr Kruczkowski
Piotr Kruczkowski
Certified TestStand Architect
Certified LabVIEW Architect
Comments
WG-
on
And does it support overflow?
PrimaryKey
NI Employee (retired)
on
What do you mean by that? It does not handle overflow in any special way. The VIs are open so you can look inside how tey work.
Piotr Kruczkowski
NJKirchner
on
I think he's talking about the overflow that can happen on the ms counter VI, so that if you are subtracting a rolled over value from a non rolled over value, you'll end up w/ some huge delta between times.
However for @WG- I think he's thinking more typically about counters rather than timers that suffer primarily from this issue; timers are not free from this potential error however.
~N
Mohamedbakr80
on
Hi, I need to make a timer similar to elapsed time Express VI in my FPGA target.
RuudWessels
on
Very nice work!
Very elegant and simple, one request (i did modify mine but it would be nice to modify yours so i can use your package.
I have added the possibility to change the goal time upon reset.
very usefull for things that have incremental timing.
Ruud R&D
Creative Engineering
PrimaryKey
on
In this case you might just stop the old timer and create a new one. Would that be a solution? I understand that in some cases restart with new target would be good but it could be confusing.
Piotr Kruczkowski
RuudWessels
on
Well it would be a solution, but personally i would not find it the most elegant one,
Codewise it's calling more VI's, the above just gives it a bit more flexibility.
Ruud R&D
PrimaryKey
on
RuudWessels, i added the function you requested 🙂
Piotr Kruczkowski
RuudWessels
on
Thanks PrimaryKey, it's become a very usefull tool indeed!
Ruud R&D
Blokk
Trusted Enthusiast
Trusted Enthusiast
on
Nice! Question: why in the VIPM (2018 with LV2018) we only get the version 1.1.0.8? At this community doc, your latest version is 2.0.0.8...
Just this can cause confusions to people...
PrimaryKey
on
Thanks for letting me know. I will try to fix that as soon as possible.
Piotr Kruczkowski
abvenk
on
Hi Piotr,
Seems like there is something wrong with the package on VIPM. The version says it's compatible for LV>=2016, but the install aborts saying it is in 2017 and higher. Could you please fix that?
Thanks!
leon1129
on
what a good tools,THS!!1
PrimaryKey
on
Abvenk, you need to update your package manager 🙂 Thats it.
Piotr Kruczkowski
DoctorAutomatic
on
I can see the similarities with the Extensible Session Framework (ESF) and notice that ESF is even linked in the OP. However, is there a reason that the ability to acquire/communicate/destroy a timer session via a named handle (string) was omitted from the Timer but happens to be one of the big "features" touted for ESF?
also, what happens to a timer session that is being used in different places when the vi, which originally acquired the timer session, exits?
