Certification
suggestions on preparing CLAD exam (My Exam on February 17th 2012)
Most of the models are from Sample Questions papers, and some 4 to 5 bits are dirctly from sample papers.I answered 20 -22 questions correctly to my knowledge.Remaining  are little tricky and confusing ,i have choose the best answers.
God gives me some luck,I will get certified..........
Message 11 of 20
(4,243 Views)
Hi.
I'm also preparing for the CLAD exam.
Read both LV core 1&2 manuals and did the two sample exams.
Are there any sample questions available that I could work before the exam?
Thanks.
Message 12 of 20
(4,234 Views)
Hi george,
The test will contains questions mostly from core1&2. If you read the both is sufficient to crack the CLAD.
Silver_Shaper | CLD
Message 13 of 20
(4,226 Views)
Hello
Check out 'The Daily CLAD'; not officially a CLAD development resource but might be useful.
Steve
Message 14 of 20
(4,091 Views)
hi,
I have the Basic I and II for CLAD prepration.
i have read somewhere about the core I and II.
are both of them same ?
can someone provide me the Core I and II ?
Thanks and Regards
Gaurav Pal
Message 15 of 20
(3,936 Views)
@Gaurav_Pal wrote:
hi,
Basics I and II turned into Core I and II.  I don't think the information has changed much at all, so you're probably fine just using your Basics I and II books.
GCentral
Message 16 of 20
(3,931 Views)
next clad exam date and eligiability
Message 17 of 20
(3,767 Views)
hi,how to apply a clad exam and date
Message 18 of 20
(3,766 Views)
You have to schedule through Pearson Vue.
http://www.pearsonvue.com/ni/
GCentral
Message 19 of 20
(3,760 Views)
Correct on registering for the CLAD.
Be sure to use both of the sample tests for preparation.  The Daily CLAD is also a good source for prepartion.
After completing the sample exam questions, consider how the answer might change if some fo the conditions of the questions change slightly.  For example, how might the output or behaviour change due to changes in the "input conditions".
Mark Ramsdale
Program Manager & CLA
Global Demo and Equipment at National Instruments
Message 20 of 20
(3,753 Views)
