Certification
Sample Exam Solutions for Review
You might need less time if you make less VI's.
I only did 1 or 2, maybe 3 in my CLD and i didn't loose any points.
Since you use Events the wait(ms) is no longer needed. I was told that.
Don't forget the documentation, i got the full 10 points just by writting a small statement in every case, full explanation on subVIs.
Try to make the VI icons more intuitive with less words and more glyphs.
My Channel: https://www.youtube.com/@LV_Lab
Message 541 of 623
(5,608 Views)
Attaching the .zip file for you.
Please check.
Thanks & Regards
Message 542 of 623
(5,584 Views)
Thank you for the response. I will work on the points you told me & soon upload another sample test.
Message 543 of 623
(5,580 Views)
Hi everyone,
I have solved the Car wash solution from the sample papers.
Please check and revert if any modifications are required.
Also, guide me on how I can further reduce my time.
Thanks and regards,
Aditya
Message 544 of 623
(5,524 Views)
Dear Forum members,
I have a sprinkler sample exam attached for review.
Thank you in advance for any comments. The specs is in the .zip file.
Kind regards,
Piotr Golacki
Message 545 of 623
(5,514 Views)
Dear forum members,
I have a security system example done in just under 4 hours.
I would greatly appreciate a feedback.
Thanks in advance
EDIT: reupload of the .zip file as some of the files in project weren't saved, my apologies for that
Message 546 of 623
(5,499 Views)
Still working with LV 2017 not able to view your code, will be good if you can down convert and share.
Message 547 of 623
(5,464 Views)
Hello!
I'm preparing to CLA exam and I tried to implement ATM controller by AF.
Can anyone check my implemetation of sample exam and give me advices?
Thanks!
Message 548 of 623
(5,324 Views)
Hi Forum Users,
I have attached my VI in LV2015 version here based on the CLD Car Wash Controller. I would be glad if someone could help me review and give me comments on how to further improve on my code and shorten my development time in the CLD test.
Thank you!
Message 549 of 623
(5,247 Views)
A fairly good CLD solution, AFAIC.
Some wires don't line up perfectly (the "Guard Clause" case and it's content, things connected to "Elasped Time" indicator (note the spelling mistake)):
I'm not sure why you made a "Stop program.vi"? There's nothing in it, and what is in it is messy.
You'll lose points on VIs without VI description ("Stop program.vi")
The timer VI's error wire is bended.
This is a bit redundant:
States "Underbody Wash",  "Soap Application",  "Main High Pressure Wash",  "Clean Water Rinse" and  "Air Dry Cycle" are all duplicate copies, minus one or two details. If you find a way to do this in one case (perhaps using a SubVI, with the cluster in and out, and a state enum to change the specific boolean), you'll actually have a new useful subVI (document it), and save time. All these cases are copies, so you could argue it doesn't cost time. But if there is a change (there obviously have been changes) you do need to maintain all of them, actually costing time.
Always room for improvement, but I'd say go for it. If it took you 4 hours of course.
Message 550 of 623
(5,242 Views)
