05-07-2012 08:58 PM
Which of the following methods will allow the execution of the custom Add VI?
A. Method 1
B. Method 2
C. Both
D. Neither
Can someone explain this one. I might guess both because both infact run the VI. Neither seems like a good option two because neither pass in values so while the VI runs, it doesn't run as one might expect. Ideas?
05-07-2012 09:14 PM
I believe the answer is both. Method 1 just gives you access to the connector pane terminals.
05-07-2012 11:43 PM
If anyone wants a hint read the "remarks" section of the help guide
http://zone.ni.com/reference/en-XX/help/371361H-01/lvprop/vi_run_vi/
03-22-2013 02:29 PM
Note that method 2 uses a Strictly typed reference, which does not work on a Call by Reference Node. See the help for the Call by Reference Node, it discusses the use of static and strictly typed static references with this node. Also, if you build this in LabVIEW you will see the error generated.
