01-30-2016 03:33 PM
Hi there,
I just tried my hand at the Boiler sample problem in preparation for the CLD. Any critique would be much appreciated. The main application is just called Boiler.VI. Thank you,
Gregory
01-30-2016 04:53 PM
Strangely, I found the buttons in the "Solution" exam were using a latched mechanism, while the front panel supplied had switch mechanism. It also was not clear to me whether you continuously log the purge time or only at the begin purge and complete purge steps. Hopefully minor details in my interpretation of the problem aren't worth that much!
01-31-2016 07:18 PM
I don't really have much input because I thought that you did a great job. I would just put everything inside of a project and do one final check for style and documentation (Undocumented Timer FGV might be some easy partial points).
I always suggest having at least some label for documentation in each state but I don't know what is really expected for "proper documentation" so that's probably more of a preference thing.
02-01-2016 08:15 AM
Not sure if it is graded on this or not but there is a VI Analyzer test that checks for this by default, so I'd suspect this might be the case.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
02-01-2016 09:36 AM
I was actually looking for VI Analyzer and couldn't find it!
I can find it easily under the Tools menu in the LV 2014 professional development suite. I did this practice test at home using the LabVIEW home bundle, does it include VI analyzer? Maybe I was just nervous taking the test.
Thank you for your suggestions and encouragement!
02-01-2016 10:27 AM
VI Analyzer is not free with all editions of LabVIEW, it looks like it is included with Professional, and the developer suite, which I think is considered Professional.
http://sine.ni.com/nips/cds/view/p/lang/en/nid/209042
02-09-2016 11:31 AM
I just did the sprinkler exam for a little more practice (and that one seemed significantly shorter). Signed up for the test on 2/19!
02-09-2016 12:24 PM
I found the actual CLD to be something like 10% harder than the practice exams. This is just my opinion of course, but my advice is to make sure you can handle the practice exam with ease, and you shouldn't have a problem with the real thing.
02-20-2016 04:08 PM
I did find it a bit harder as well, but also more clear of what they were asking. I think the worst part was that I was working on a laptop instead of my normal 2 monitor setup. I'll report back in 4-6 weeks!
03-01-2016 03:10 PM
It is. You might lose a partial to a whole point depending on other factors and the graders opinions of the rest of the documentation but you will almost surely get a comment on the review for not commenting each case and structure.
