03-03-2013 11:37 AM
I finished the ATM practice exam in just under 4 hours and it seems to be working as it should. I spent the last hour figuring out how to write the updated data to file and trying to add some documentation. For some reason when I write to the text file I get extra blank elements in the Accounts file. It doesn't affect how the program works from what I can tell but it is bugging me. Thanks in advance for all comments.
03-12-2013 06:56 AM
oh wao its looks to me you have done all the things quite effieintly. wish you best of luck for rest of your life.
03-18-2013 08:06 AM
Thanks for the feedback!
03-21-2013 10:22 AM
First learn how to use projects effectivly. Pull your project dependancies into the project! see below:
BAD BETTER
Next. How do you change states? Really how does the value of "State Out" effect the case seletor of the next while loop iteration? I'm pretty sure you will need a shift register or feedback node in there somewhere
Did you run VI Analizer? It would have saved you from yourself for these overlapping tunnels (Duplicated in Withdraw and Fast cash!)
Yet the wire dot before the string tunnel and slight shadow on the string tunnel itself might have peaked your interest!
Try it again.... you can get there... Run your code next time.
03-21-2013 11:20 AM
Ignore that part. Somehow I got confused between the GUI and the AE. There is a bit of code stench in there when you have two levels of vis with identical case selectors. Easy to get lost.
