05-25-2018 08:45 AM
I am trying to copy one of the "FGV Timer.vi", but there are lots of errors in the block diagram:
1. The "time target" shift register is not enabled.. the line is dashed..I simply added a shift register, is it correct?
2. on the right side, "has time elapsed" has a bad terminal.. maybe it is related to the first question.
Thanks so much!
05-25-2018 08:57 AM
Hey,
05-25-2018 09:13 AM
thanks.. but the sample VI that I copied from, that Register did not connect to anything.
then, how to initialize it?
05-25-2018 09:17 AM
I connected it to the " time target" indicator, as enclosed..
but it did not seem right for me since it is not the same in the sample VI.
05-25-2018 09:18 AM - edited 05-25-2018 09:20 AM
What sample VI did you use ? I highly doubt there was nothing connected to the shift register inside or outside the loop.
Example here :
05-25-2018 09:19 AM
CLD 3 and 14 in the success package..
05-25-2018 09:23 AM
The command highlighted is sent into the shift register inside the loop, thus setting the data type used by the mentionned shift register.
05-25-2018 09:26 AM
THanks, but how to do it?
I still get the dashed line, if I disconnect the register to the indicator..
05-25-2018 09:31 AM
05-25-2018 09:36 AM
thanks so much.. problem solved:)
do we need to put the "default case" as the first case always?
