06-19-2013 09:42 AM
Hello every one
I am taking cld exam in july 1
I have practiced the sprinkler example .
Please give me feed back where to improve myself
Thank you
06-20-2013 11:35 AM
For starters I found one bug: when you switch from no rain to rain the sprinkler that was running stays running. Don't want to waste water.
06-21-2013 12:47 AM
What about the coding style ?
Are there any points to consider for better coding techniques ?
06-21-2013 11:00 AM
Your coding style and documentation are fine. When taking the test just make sure the code actually works. If you can accomplish this in 4 hours you should not have any problems passing your CLD exam. Good luck!
06-21-2013 04:45 PM
That the beauty of learning those project templates! the documentation and style are right out of the box!
your customized subvi's, on the other hand, lack proper names and icons. "Read from XML" should read from XML when reading a speradsheet you should name the vi something like "Read Config from Spreadsheet.vi"
I Don't know the "Official" Policy but if I was a grader I'd give points for using the template but grade the developers code to the same standard as the template vis. Did this examinee really go to school with these templates and pick up the style? would be my first question.
06-22-2013 12:47 PM
The code and the pattern looks fine. Here are few things to note:
Just my personal preference, I like the statemachine template that ships with LabVIEW that incorporates event structures as well. But use the design pattern you are comofortable with as long as you can do it in 4 hours. Make sure to run your VI through VI Analyzer as well. Plan to allocate 5-10 minutes for that towards the end. Good luck !
