04-02-2018 08:54 AM
for CLD exercise 1, I did not use the "invoke node" in the beginning.also before the error out, I did not use the "simple error handler".
it seems working too.. but how much points would be deducted in this exercise?
Solved! Go to Solution.
04-02-2018 10:05 AM
Hi idjuven,
After reviewing your code and the requirements, I think that not having the invoke node wouldn't get you all the points as for the functionalities. It is clearly stated that you need to initialize the front panel as shown in Figure 1, which might not be the case in your code. E.g. if you leave the Auto Reset button set to false before starting your VI...
I would then recommend to use the invoke node or any other way to make sure that your front panel is initialized properly.
For the Simple Error Handler, it really depends if this is your main VI or not. If your VI is meant to be used as a SubVI, then do NOT use the Simple Error Handler. You don't want your subVIs to trigger error pop-ups one after the other thus stressing the user.
If your VI is the main VI, NI recommends to use the Simple Error Handler at the end of the application to alert the user of any error that would have appeared. Nevertheless, having a proper error handling strategy (like log and erase, or stop the application properly) within the code is good option. You should plan ahead about the way the errors may affect your application and then take the right actions.
Hope it helps, feel free to ask questions 🙂
07-03-2020 12:53 PM
07-03-2020 12:53 PM
