Certification
Reply
CLD-R paper 2 - question 33
Hi All,
For the code below , Ans is given as A(execution of invoke node generates an erro ). is this correct?
shouldnt the answer be D(code will execute without any error).?
Message 1 of 15
(3,434 Views)
Accepted by topic author LV_user1
10-12-2015 12:18 AM
Re: CLD-R paper 2 - question 33
My guess was A before seeing the answer is A, and a quick test confirms it.  The error is generated because you are attemping to set control defaults, of a running VI which you can't do.
Unofficial Forum Rules and Guidelines - Hooovahh - LabVIEW Overlord
Interesting in learning all you can about automotive CAN bus communication? Checkout my 12 part CAN Blog series.
Message 2 of 15
(3,425 Views)
I hate the CLD-R exam so much that I take the extra year NI allows before sitting for it.  I thought of taking the CLA to avoid it, but there's the CLA-R.
The moral of this story is to recertify by earning points.
Jim
Message 3 of 15
(3,423 Views)
You can't change the code of a VI that is running.  Since it is trying to change code of itself, you will get an error.
I have heard many horror stories about the CLD-R, but this is a question that is really straight forward.
Message 4 of 15
(3,417 Views)
Hi All,
I completely overlooked the question.
I thought the property of invoke is Reinitialize all values to default which executes in run time also..
This CLD-R is not a easy job it seems!! huh...
Message 5 of 15
(3,393 Views)
@LV_user1 wrote:
Hi All,
No, it is not!  The CLD asks you to demonstrate some compentancy in delivering a solution using good software practices in LabVIEW.  The CLD-R Exam asks you to demonstrate the knowledge.  "Can you do this?" and "How would you do this?" are definately different questions!  The Self-Paced Online training can be a valuable resource in passing the CLD-R Exam.
Recert by Exam requires that you keep up studying SE in a LabVIEW environment.
Recert by Points shows about the same interest in personal growth!  In fact, some of those courses are worth recert points (More if you teach them! and, if you really want to learn something try to teach it!)
That being said: I have a Failed and a Passed CLD-R by exam under my belt....And a CLD Recert-By-Points waiting for next April to be active.  Some would say I should have just CLA'd instead of re-certing CLD (Stop it Tim!)
Message 6 of 15
(3,376 Views)
I have nothing more to say at this time...
Message 7 of 15
(3,368 Views)
Just interested, why haven't you gone for CLA?  Crossrulz's questioning has made me believe that it's some deep dark secret.
Also Crossrulz, your signature is kind of messed up.  I don't know if there is a size limit but it cut's off like half of your link.
Matt J
National Instruments | CLA
Message 8 of 15
(3,355 Views)
Not so much a secret, Tim just loves giving Jeff a hard time about not taking it, as an observer, it makes me laugh every time.
Message 9 of 15
(3,346 Views)
Why would YOU laugh?  (Ahem- someone needs to take a test)
No, it is no "deep dark secret"  The level of competancy between CLD-R and CLA is essentially moot.  CLD is more "Approachable" to my clients.  Moreover, (comma. pause for effect) until receintly my NI Certification period would have been SHORTENED by taking the CLA (good for 4 only years) over the CLD Recert-by points that isn't even active yet.  That's 4 billable hours I do not need to sacrifice for a while to pass the CLA exam.  (I believe I can justify the exam cost with certain arraingments)
But, Tim just keeps giving me crap because he likes to visit Austin in March and misses me.
Message 10 of 15
(3,341 Views)
