02-21-2018 04:11 AM
hi everyone
if someone fail in passing the CLD certification exam , what is the periode that he need to wait to re-take the exam?
thanks
Solved! Go to Solution.
02-21-2018 12:08 PM
You can attempt it twice in 6 months. If you are retrying it, I believe you can get 50% off by emailing the certification team.
See page 3: https://www.ni.com/pdf/custed/us/cert_faq.pdf
02-21-2018 12:24 PM
thank you gregoryj
03-28-2018 06:37 AM
03-28-2018 11:15 AM
Know how to quickly bring up your framework of choice, either from memory or from one of the NI project templates. It will be good to have 2 or 3 in your head and choose the one that best completes the problem, though a state machine is often a great place to start.
I don't know if the actual exam is harder, but I was definitely more nervous on test day. I was required to bring my own laptop for the exam, but I was not used to the laptop keyboard, so I brought a USB keyboard and mouse as well 🙂
03-28-2018 01:27 PM
@பரத்_குமார்(bharathkumar) wrote: Any tips or tricks to reduce the time for development.
QuickDrop and the shortcuts in it. There are even default shortcuts as of LabVIEW 2016.
03-29-2018 01:49 AM
Hello Gregory,
Architecture wise, state machine has been removed from template . i have seen .ini file read and write from examples, which i am planning to use. Any other I can use from examples??
Talking about Nervousness, Even thinking about the time duration scares me
03-29-2018 01:53 AM
03-29-2018 10:44 AM
Hello Gregory,
I was using the JKI state machine a lot around the time of my exam, so I used this blog to help recreate it quickly. With some practice you should be able to make it in about 10 mins.
http://blog.jki.net/community/pass-your-cldcla-exams-the-jki-way
