04-30-2018 03:22 PM
I took the CLD last Friday, and I have a few suggestions for NI on the exam and sample exams:
1. It would be helpful to add something similar to a rubric to the end of the sample exam pdf documents to show where the functionality points will come from. There is an example here (in Excel, though): http://www.ni.com/tutorial/14554/en/#toc1
2. It would be helpful to include a searchable pdf of the paper exam on the exam flash drive. This would not replace the paper copy of the exam (the paper copy allows you to not have to constantly switch between the code and the requirements). Being able to search the requirements was quite useful in some of the sample exams.
3. The Car Wash Sample exam had a slider with a requirement to set it back to 0 when the user moves it to exit at the end. This is quite annoying to do: you can write 0 to it on each value change event until you see a mouse down event (the mouse down signifying a new attempt to change the slider; there may not be a mouse up event during the original move to exit, as the user may release the mouse over another control), but it still flashes back and forth from wherever the user is clicking to 0 occasionally. The example solution just attempts to write 0 to it once, so the slider stays at exit. It may be better to remove this requirement from the sample exam (and any other exams that use sliders for simulation) unless this complexity is intentional.
04-30-2018 04:58 PM - edited 04-30-2018 04:59 PM
Hi ortt,
I hope your CLD went well. Do you feel confident ?
To answer your question :
Anyway... That is just an opinion and I am more thant willing to discuss that with you.
04-30-2018 05:56 PM
Hi ML927,
I do feel confident. I had working code that met all/most of the requirements, I added help documentation, comments, and non-default icons to all vis and ctls, I added descriptions and tooltips to all the front-panel controls, and I had few VI Analyzer failures at the end.
1 and 2 are to make the sample exam and the real exam more similar to each other. For 2, I was under the impression that you aren't able to keep a copy of your code after the exam is over (and therefore wouldn't be able to keep the PDF either).
For 3, it was a complaint about a requirement that is extra difficult to meet (probably for unintended reasons). There is no good way to set the value back to entry when the user changes the value to Exit, as there is no way (that I am aware of) to "unclick" the mouse. This would not come up in normal usage of a slider bar, as you would not normally try to set a slider bar's value while a user is clicking on it. I cannot think of any good solution to do that, as the best one I came up with still flickers back and forth between Entry and Exit until the user releases the mouse. I only brought up the sample solution because it implemented the obvious (non-working) solution of setting a local variable when the state changes.
04-30-2018 07:08 PM
1) I don't remember having specific details about the grading system on the exam, only the generic thing with style, documentation and functionalities. That may have changed though since I took the CLD...
2) Whenever you have an e-file there is a risk to see it get out on the web, should it be someone sneakingly using his own USB drive to transfer the PDF. I guess that NI cannot take that risk to have to create a new exam and potentially have to localize it each time (plus change it if it was sent out to the exam centers).
3) I see what you mean. In the case of that specific solution changing the loop timing solves the problems. Yet that might be a reason why that exam is not given to people anymore, even if it is still an interesting training material.
05-01-2018 03:06 AM - edited 05-01-2018 03:08 AM
I found the attached approach worked for resetting the car wash slider.
