Certification
CLAD Solution of Sample exam
I found this sample exam on the web but without answer ...
Can someone help me about the answer ?
Sample exam : http://202.38.93.17/bookcd/3503/1.iso/CERTIFICATION/CLAD+Sample+Exam.pdf
(8,268 Views)
Well, that's only the first three pages of an obsolete sample exam.  Better yet- what do you think the answers are? which are you not sure of?
"Should be" isn't "Is" -Jay
(8,239 Views)
Thanks for the answer..
I give you my answer :
1 and 2 : D (for me the same answer for the two)
3 : A
4 : A
5 : C
6 : D
7 : B
8 : A
9 : B
10 : A
11 : C
12 : A or B ???
13 : A
14 : B
15 : A and B ???
(8,236 Views)
#4 search the forum- that conversion is maybe half the speed of a coersion-  Let thos Coesion dots WARN you about potentioall lossy coersions (especially on Enum data types) but they are not evil.
#5 look up buffer re-alocation.
#6 is a deadlock (One of those aweful questions on terminology used in Basics 1&2 - the tests are improving)
#9 is an obsolete question (although you were correct for LabVIEW 7.0) What colors of Property Nodes can you find and what do they mean?
#10 "Methods" are involked- Read right through that didn't you?
12 Probably a really badly worded question (as well a #15) read Ben's nugget on Action Engines and you'll learn better ways to pass data between threads within an application instance but "GLOBALS are not evil- Lighting fast little buggers and that can be pretty handy
 http://forums.ni.com/t5/LabVIEW/Community-Nugget-4-08-2007-Action-Engines/m-p/503801
(8,228 Views)
Is it ok for the others question ?
(8,225 Views)
If you are interested in other CLAD questions:  Check out 'The Daily CLAD' blog
Steve
(8,164 Views)
