03-29-2018 06:16 AM
Has anyone looked at this questions? The suggested answer is D.
The correct answer however should be: B and D.
Solved! Go to Solution.
03-29-2018 06:59 AM
In B - The Build Array has concatenated inputs and therefore just produces one trace, Sinewave 5Hz followed by Sinewave 1Hz.
03-29-2018 07:04 AM - edited 03-29-2018 07:05 AM
Are you referring to this one?
The answer is definitely D. There are two plots in the graph. Therefore you need a 2D array. Notice with B that the output of the Build Array is a 1D array. It has been configured to "Concatenate Inputs".
So since we know the output must be a 2D array, A and B are eliminated as possible answers. C will add additional data (using Insert Into Array), so it cannot be the answer. So we are left with D.
