Certification
CLA sample exam car wash broken
When I try to open the main VIs in the 2012 projects for actor objects and actor framework versions of the car wash example files, I get an error "memory or data structure corrupt". I assume it may have broken when someone converted from the 2016 down to the 2012. I don't have 2016 to see if the same is true for the 2016 versions.
Could someone please help with this.I have attached the sample exams here. Could you also check that the 2016 does not have issues as well.
(4,327 Views)
Accepted by topic author iam_SOLID
I'm using LV 2016 and both projects from the 2012 folder open fine for me.
(4,298 Views)
I have used the 2016 and all the examples work. I also tried to make a previous version but the LabVIEW 2015 still encountered an error. There seems to be something wrong with the way LabVIEW down-converts actor framework.
(4,250 Views)
Someone should have pointed you here a long time ago.
I'll take the blame.  I've let the Certification board idle on its own for a while.
"Should be" isn't "Is" -Jay
(4,156 Views)
