07-27-2015 02:18 PM
I find it useful in the practice exams to add a '#' in front of the tag comment - eg. #[Covers: UI1]
This adds the comment to the bookmarks list so I can easily see and jump to my tags later.
Will adding the # upset the marking? Technically the comment sitll fulfills the requirement as stated in the instructions, but I would hate to flunk out just because RG failed to recognise them! Anyone got any experience of RG or of marking the CLA?
07-27-2015 02:39 PM
I have used RG, but I think only NI can answer this, because it really depends on how they find the covers tag. If they wrote it to find a comment, or description that starts with [Covers then it won't find it, if they wrote a proper regular expression then it would find it anywhere.
Now that I think about it you can put more than one covers tag in a single comment so they must have the regular expression written in a way that it would find it, which makes me think it would still find it if you started with a #.
If this does work it is a good tip.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
07-28-2015 02:18 PM
07-28-2015 03:15 PM
Thanks Fisel, good to know for sure 🙂
08-20-2015 01:31 PM
Coincidentally, I now prepare a presentation (Germany) touching this special topic.
If you use Covers-Stements only in comments of block diagram, the thing with the # works.
(the # must be before the brackets AND the # must be either at the begin of a comment or preceeded by a space or newline
-> if you would write "#[Covers: A]#[Covers: B]", bookmark manager wouldnt find the second)
Generally, your trick is only useful, when you restrict using your covers-statements only in areas, where they are also
acessible by the bookmark manager.
But in the CLA exam, I find it also useful to make a documentation of front panel elements or fill the documentation
section of a vi and use covers-tags also there -> these wouldn't be found by the bookmark manager.
If you still have enough preparation time, why not install an evaluation version of NIRG and try yourself what is possible?
08-20-2015 01:50 PM
Thanks for the extra info, T. I actually sat the exam 2 weeks ago - just waiting on the results now 😕
I used this trick in the exam, but in the end I was so pressed for time that I couldn't make good use of it - ie. I did't have the time to go back over the requirements and check them which is where this would be useful. However, I think using bookmarks like this will be of more use in future projects that have formal requirements specs and will speed up code reviews, validation, etc.
08-20-2015 03:14 PM
So, I wish you success.
Having some useful tricks or tools for the exam is one good strategy,
but another good strategy is, when this special trick does not work 100% in the exam (due to nervousness etc.),
that you keep in your mind the actual task to be done (to be prepared to pass even without these "useful helpers")
-> when I prepared for CLA two years ago, I tried to use RequirementsGateway as preparation (for checking my sample soulutions)
but as I did something wrong [I didnt know what? - something with spelling?] NIRG didnt analyse my VIs correctly.
So I decided, not to spend too much time on NIRG during preparation but instead "simply" train to develop solution architectures efficiently,
hoping that the covers-tags set in exam will be ok...
