Certification
CLA Attempt- Car Wash
Hello LabVIEWers 🙂
Can you please evaluate my attempt to solve the Car Wash sample exam using LV2016.
My real exam is in 6 weeks, and I need your feedback what I need to improve.
Kudos for any good advice 🙂
Mohamed
Spoiler
(3,466 Views)
Hello Mohamedbakr2,
Few observations,
1. Hardware interface has not been implemented.
2. Modules queue reference has not been released.
3. Name Queue, could be an issue, as possibility of rogue message.
4. No need to wire (Event Dynamic registration terminal) through event structure.
Hemant
(3,405 Views)
Thanks Hemant for your reply,
1. Hardware interface has not been implemented.  Do you recommend a way to implement it? Should it be a parallel module?
2. Modules queue reference has not been released. Should I release it at each module exit loop?
3. Name Queue, could be an issue, as possibility of rogue message. the naming comes from the VI name, which is unique for each library.
4. No need to wire (Event Dynamic registration terminal) through event structure. Got it 🙂
Mohamed
(3,402 Views)
1. You can check Elevator sample exam for hardware interface implementation.
2. Releasing at exit state may cause error in event handling loop as you have API in event handling loop also.
May be good way to release outside the both of the loop, release where you have unregistered the user event.
3. Though you have unique library, there is possibility to generate rogue message by developer.
Hemant
(3,396 Views)
Accepted by Mohamedbakr2
A few suggestions:
1. Add context help to your VIs. Most of them are just empty so it's not clear what any of the VIs are supposed to do.
2. Consider changing the variant input of all of your API VIs to some specific data type which developers are supposed to use.
3. I would add more documentation on how the application is intended to operate. This combined with the fact that many of your API VIs don't have any callers makes it a bit unclear how everything is supposed to fit together.
As an FYI, Tools > Options > Front Panel there is a check box for "Use numbers in icons of new VIs (1 through 9)" which will make it so you don't have to just delete all of the numbers on the VIs when creating icons.
(3,321 Views)
