09-18-2019 04:17 AM - edited 09-18-2019 04:20 AM
Hi All,
I have a UI which is acting really strange. I've never seen this before and not sure what is causing it, hoping someone can help!
I basically have a system tab control with buttons which I am using as a wizard, the tabs are hidden at runtime. What is happening, at runtime and in development environment, is that the buttons disapear and reappear at random when hovering over with the mouse. Below is a video
The video was taken in the dev environment, but the same thing happens when built.
Does anyone know what is happening and how I can resolve this?
Greg
09-18-2019 04:36 AM
Can you include a minimal version I can play with LV2018 or lower would be good
I've not seen it before...
Steve
Opportunity to learn from experienced developers / entrepeneurs (Fab,Joerg and Brian amongst them):
DSH Pragmatic Software Development Workshop
09-18-2019 04:56 AM
Hi Steve,
Attached is a single vi which has the same behaviour, LV2018SP1. I've removed pretty much all the logic!
Have a look at Step 2, when hovering over the buttons they disappear. I have set up tabbing so when they are tabbed to, they pop back. Very strange indeed!
I haven't tried replacing the buttons with another style but don't see why this will be an issue as I've used them before without any issue.
Cheers,
Greg
09-18-2019 06:06 AM - edited 09-18-2019 06:09 AM
Works fine on Win 7 32 Bit, with this loading
Steve
09-18-2019 06:43 AM
Thanks Steve,
I've just tried replacing all the buttons with Silver styled buttons and it seems to work. I'll replace them all back to System and see what happens.
Really strange and a bit annoying!
09-18-2019 09:17 AM
Replacing all the buttons seemed to fix the problem. Seems a bit strange but will just keep an eye on it.
Thanks Steve for testing it on your system
09-18-2019 10:23 AM
No worries matey,
I reckon the button instance had corrupted.
Steve
09-19-2019 04:09 AM
Was first button corrupted and then copied to remaining buttons?
09-19-2019 04:15 AM
Yes, but it worked perfectly when I originally wrote the software.
I did have to reinstall LabVIEW on my PC a few days ago which also reinstalled the System UI Control Suite using VIPM, where the buttons came from. Thinking about it, I should have tried a mass compile before replacing the buttons!
09-19-2019 04:46 AM
It is never to late.
You have got broken version saved in source code repository, haven’t you?
