CSLUG - Central South LabVIEW User Group (UK)
Register Map Data Structure
Has anyone come up with a good way to define a series of register maps?  I was thinking of creating a set of polymorphic vis contains a strict typedef refun...I'm sure it'll work but just wondered if anyone has any other smart ideas.  In the past I've used ini files to contain the registers definitions, it's nice to have the definitions in a text file but a bit of a pain to use...
Here's an example register map....
Module
Index of Special Function Register (SFR)
Module
Specifier
00000
00001
00010
00011
00100
0101
00110
00111
01000
01001
01010
01011
01100
01101
01110
01111
AP
01000
AP
APC
PSF
IC
IMR
SC
IIR
CKCN
WDCN
A
01001
A0
A1
A2
A3
A4
A5
A6
A7
A8
A9
A10
A11
A12
A13
A14
A15
PFX
01011
PFX
IP
01100
IP
SP
01101
SP
IV
LC0
LC1
DPC
01110
Offs
DPC
GR
GRL
BP
GRS
GRH
GRXL
FP
DP
01111
DP0
DP1
So in this case the register is 10 bits made up the module section + SFR section.
There will be multiple registers with a similar format.  I was thinking that each register will have a set of polymorphic vi's that would select the "Module", each module vi would then expose the available registers to the programmer.
Message 1 of 1
(4,127 Views)
