CSLUG - Central South LabVIEW User Group (UK)
Identifying a function on Filter Vi
Morning,
Came to a couple of meetings when Ocis Consulting and I'm after a hand again..............never did my exams so not on the TAP, big regret especially as now discontinued.
Have a basic labview ques:
Trying to move away from Express Vi now i'm back using Labview, in this instance mainly as i want some user control on the front panel.  I found an example somewhere on a long dead thread somewhere but have no idea what the function is with the coercion dot that outputs the waveform is. If somebody could identify it for me that would be great (dont remember it from core 1 or 2). I need a better understanding of filters in general, but would be good to get it running before i dig further.
Thanks for any help in advance.
Kind regards
Martin
(5,803 Views)
Hi 🙂
I have a new laptop and don't have LabVIEW installed yet! 😮 and I don't recognise it.  EDIT: I think that's the IIR Filter.vi
But,
  1. Right click the function you can select Visible Items>Label. That will tell you the name of it.
  2. If this function appears in the functions pallets, then you can right click the BD (to open the functions pallet) then in the search icon at the top, type in the VI name you found earlier and it will take you to the pallet.
Hope that helps
(5,798 Views)
I can't remember for sure, but I'm pretty positive there are filter examples in the NI Example Finder.
http://www.ni.com/getting-started/labview-basics/examples
(5,796 Views)
Afternoon Tom,
Thanks for the reply, unfortunately only the jpeg was posted so don't have the vi.  I went through all the pallets and the examples and couldn't see anything as simple, but will have another look.
Maybe I'll try and find the old thread and see if the OP is still active.
Many thanks
Martin
(5,794 Views)
What is it that you're actually trying to achieve? Knowing that we can point you towards what you need as opposed to this VI, which might be a red-herring for your application.
(5,792 Views)
After the smoothing filter with the time, and type user defined on the front panel, or even read from a config txt file if i have to
(5,790 Views)
Oh sorry didn't see you reply,  Really just trying to move away from express Vi is the driving force.  Funny enough I'm still have problems even with the express Vi.
The new post will put a bit of history around it.
Thanks for the reply sorry again for lack of reply
Kind regards
Martin
(5,655 Views)
