CMC Driver Framework
Installation: No Products Listed for Available Driver Framework Products
Problem: I tried to use the Driver Framework Installer but the Available Driver Framework Products showed up empty and there was a status of "Unable to return list of packages in the feed. Check the feed location has a valid feed and packages."
Solution: The computer was unable to download the Packages.stamps file so that the installer could properly identify the available products.  A work around for this is to follow the instructions in section 2.2.2 of the attached Driver Framework User's Manual to install the product(s) that are of interest to you.  The feed should have already been registered as df-feed in NIPM.
Message 1 of 1
(950 Views)
