CMC Driver Framework
Injecting a command into the Console results in a console error "Unable to inject into a closed connection."
If the Console returns and error saying that it is "Unable to inject into a closed connection." check that an Open command has been called from the API.  Version 1 of the Driver Framework Core requires the Open function be called after the Initialize and Load functions in order for the  Console to recognize the instrument resource as open for injection.
Message 1 of 1
(1,225 Views)
