BreakPoint
Ya know it's going to be a bad day when.....
You have typed a big reply and click send and when you wait for 1/2n hr and you see it processing something  and you again wait and u occasionally check the status  but the result .........................................
You need to retype the msgSmiley Sad
Message 91 of 108
(11,871 Views)
For any longer messages, I usually do a [ctrl+a .. ctrl-c] before any post or preview operation. This way, I can just paste it again if the operation fails for some reason.
Message 92 of 108
(11,859 Views)
Good suggestion Altenbach.  I do that every once in a while..
Unfortunately, I do get what happened to muks, but usually when I don't copy all....   <<go figure>>
Message 93 of 108
(11,850 Views)
Nice suggestion altenbach.I have started practising that. Actually am forced to practise this........
Message 94 of 108
(11,818 Views)
You get this after 1/2n hr of waiting.......................
Message Edited by muks on 08-21-2008 04:51 AM
Message 95 of 108
(11,817 Views)
You do have to love those wonderfully informative error messages...
 I enjoy looking up an error code from LabVIEW and seeing, "Generic error." 😛
     Rob
Message 96 of 108
(11,800 Views)
<Irony> Yes, enjoyed that Generic Error a while ago. Had a wonderful time searching the forum. </Irony>
Felix
Message 97 of 108
(11,764 Views)
LV Error Code Trivia:
The Error codes can and will change depending on the driers and the machine the code runs on.
Example:
If you are working a LV-RT app that is interacting with a FPGA and you get an erro that "Explain Erro" does not translate. Try doing the "Expalin Error" using a VI that is open on the machine where the error was declared. You just might get a translation.
Ben
Message 98 of 108
(11,755 Views)
The most frustrating pop up i get is something like labVIEW closed unexpectedly
  • Investigate error now
  • investigate error later......
Message 99 of 108
(11,754 Views)
YKIGTBABD when you wake up exhausted after spending what seemed like an eternity having a nightmare about trying to create a test executive module using BASIC. All those line numbers- ugh. Have no idea where that was conjured up from.
-AK2DM
Message 100 of 108
(11,653 Views)
